Microsquirt and bluetooth module HC-05
Hi everyone,
I managed to squeeze the bluetooth module inside the microsquirt case and wrote a DIY about it http://www.makestuffblog.com/2016/01/31 ... crosquirt/
Hope you find the DIY useful. Applying it to Megasquirt should be similar.
Cheers,
Olaf
EDIT: moved website to new address http://makestuff.66ghz.com/2016/01/31/a ... crosquirt/
Cheers,
Olaf
Re: Microsquirt and bluetooth module HC-05
Hey this is good stuff !! I always like learning new stuff. I am lost in the arduino stuff I know nothing about it can you explain that part? and thanks for share this info!!
Frank Racing,Naranjito Puerto Rico,installations and tuning solutions
FrankRacing.Naranjito@gmail.com
Why use the Arduino? A serial connection to the laptop / PC should work, with the appropriate adapter circuits, obviously.
Now I'm more lost. How I do tha? There is a software I can download for that? I really want to do this.
Thats correct. Yet for someone doing it for first time I would still recommend to use Arduino IDE and its serial widow. Less settings to worry about. +Arduino is cheap + a lot of tutorials to get started. (And afterwards you can use Arduino to test your MS on bench, ie. send tooth wheel signals etc.)dontz125 wrote:Why use the Arduino? A serial connection to the laptop / PC should work, with the appropriate adapter circuits, obviously.
And also, Arduino works over USB (has serial converter chip on board), in case one doesn't have serial connection on pc.
Remind me again what the Arduino is for, aside from "sounding cool" ? You can't tune the Microsquirt with it can you?
Ok I'm ordering mine today.There is anything more to buy? And how I change the baut rate only with my laptop? Thanks, Frank
I think he is using an Ardino to "tune" the BT adapter.
Can't that be done with a shell script?
I set up my BC04 module with HyperTerminal. It is mostly just changing the BT modules baud rate from what it ships with, to the megasquirts baud rate.
Cheers Luke
Cheers Luke
Ofc any terminal can be used to send the AT commands (to set baud rate and optionally device name and pairing password). I don't have serial on my laptop so I needed some hardware for USB-serial and I happend to use Arduino for that.
Ok so hyperterminal in windows should work?
I have this one. It has everything on board as opposed to just the bare module.
Cheers Luke
Cheers Luke
The problem with Microsquirts is in the serial connector therw is no 5v and you have to wire that externally.In my case,I had problems with that because I was using a car lighter style power outlet and wasn't always working right and I use msdroid to record the pass in the 1/4 mile with that and the log is incomplete because the 5v come aut or a bad contact in the power outlet
Yes those lighter sockets are terrible for dropping out power.
Cheers Luke
Cheers Luke
I definitely will try this. But im a little lost with the part of changing the baud rate mabe I can find one already with the right one or ask the seller if he can make the change fir me.I will have to wait because the seller says is out until February 13
In this case, it would be best to cut off the jack socket and wire in a regular DB9 serial connector - with 5V.chango de naranjito wrote:The problem with Microsquirts is in the serial connector therw is no 5v and you have to wire that externally.
That's a good idea too. Thanks!!
I would suggest that will overload the uS 5v power supply. If you're going with an external unit, try to pick one that can eat 12v.
I have the one that Phil sells.
have you got this guy to work as i was looking at them??slow_hemi6 wrote:I have this one. It has everything on board as opposed to just the bare module.
