85 Honda CRX Racecar
I finally got the wiring almost done. The wires in the interior run the shift buzzers and the CAN network stuff running a Microsquirt IO Box in the future.
http://www.nbs-stl.com/CRX/CRX%20Interior%20Wiring.jpg
http://www.nbs-stl.com/CRX/CRX%20Dash.jpg
http://www.nbs-stl.com/CRX/CRX%20Engine.jpg
Here is the ignition. I will use the stock ignition with three of the four points ground off to create a cam position sensor. The original CRX ignition cap is just a dust cover now.
http://www.nbs-stl.com/CRX/CRX%20Ignition.jpg
The terminal strip is clean ground for sensors and ignition digital stuff on the left and high power grounds on the right.
http://www.nbs-stl.com/CRX/CRX%20Intake.jpg
The ITBs are off a GSXR with 30 lbs injectors from a Yamaha FZ1.
Next I have to sort out a cranking issue. Then taking on the first start-up verification.
Here is a wiring diagram that is fairly close to the final setup. The shift buzzers are on the upper left.
http://www.nbs-stl.com/CRX/Civic%20CRX%20Wiring.jpg
Andy
Andy
Last edited by whittlebeast on Mon Mar 21, 2016 12:34 pm, edited 2 times in total.
Re: 85 CRX Racecar
Here is the main relay panel. The wiring changed slightly in the final wiring compared to this shot.
http://www.nbs-stl.com/CRX/MRC_1%20Relay.jpg
and here is the shift buzzer relay panel that I found for like 6 dollars on amazon. The relays are triggered by the 4 spare 5 volt programmable ignition output channels.
http://www.nbs-stl.com/CRX/Small%20Relay.jpg
It is set up like this in the squirt.
http://www.nbs-stl.com/CRX/Shift%20Timi ... 0Setup.png
Andy
Andy
Re: 85 Honda CRX Racecar
Update. It started right up. First try, the motor ran for about 2 sec and died. Second try, same thing. Disconnected the cam sensor to force wasted spark and it fired right up. Base timing was within 5 degrees. Fuel pressure came up about 60... no big deal. Time to start tuning.
I can post some logs if people want to watch how I bring a car up from scratch.
Andy
Andy
Nice work Andy. Makes me a bit nostalgic about my old D16 twin cam integra.
Cheers Luke
Cheers Luke
Here is a few screen shots after a little playing on the dyno. It came up 125 HP at 7000 RPM The guy that owns the dyno builds Spec Miata motors and tells me that his dyno reads about 7 HP less than a Dynojet dyno that most people quote, so call it 132 HP. Multiply by 1.15 and you get 152 HP at the crank. Not too bad for a 30 year old, 3 valve, 1500cc motor that Honda rated at 91 HP.
http://www.nbs-stl.com/CRX/CRX%20Dyno%20Graph.jpg
http://www.nbs-stl.com/CRX/Dyno%20Pull%20Graph.png
http://www.nbs-stl.com/CRX/Dyno%20Pull%20AFR.png
Andy
Andy
Here is a dyno pull
https://www.youtube.com/watch?v=-mUGL6i0rpg
and watching the fuel pressure regulator at WOT
https://www.youtube.com/watch?v=HGFV11KjfqQ
Andy
Andy
The car ran great all day. Never missed a beat. I have some tuning to do. I am planning to go to a base speed density tune with a Alpha-n secondary table.
http://www.nbs-stl.com/CRX/CRX%20Basic%20Usage.png
Andy
Andy
I got the Accelerators working this weekend. Here is data coming of an autocross. Here is a couple of screen shots.
http://www.nbs-stl.com/CRX/CRX%20Traction%20Circle.png
http://www.nbs-stl.com/CRX/CRX%20Autocross%20Trace.png
I did it with a $3.00, 3 axis, 3g board and a 3.3 Volt converter from Amazon. It is in a box, located just under the windshield surrounded in memory foam.
Here is a pic of the engine compartment. The accelerator is the black box.
And the car pic....
http://www.nbs-stl.com/CRX/CRX.jpg
And my son driving it.
https://www.youtube.com/watch?v=3iNdHm81lgs
Andy
And the car pic....
Andy
Very cool!
Graduate of EFI University.
Thanks.
I am starting to think that you can't run closed loop and using autotune is fairly sketchy with anything that is this flying around the VE map this fast. I may have to resort to hand tuning.
No big deal.....
Andy
No big deal.....
Andy
I got MLV HD to work with my QStarz data.
On the left, the color is MPH, and on the right, red indicates acceleration and blue is braking.
http://www.nbs-stl.com/CRX/CRX%20Autocross%20QStarz.png
Andy
Andy
Really cool car and Electronics!
Sent fra min C6903 via Tapatalk
Nyborg Garage, Norway, Honda Tuning.
www.facebook.com/nybga
I spent some time working on looking at autocross data coming off the new setup. Here is what 7 autocross runs worth of data look like. I filtered out data below 15 MPH to get rid of data warming up the car and driving around the pits.
http://www.nbs-stl.com/CRX/Autocross%20CRX.png
Then I did some playing around with the Histogram graphing capabilities that comes with the registered version of MLV HD and came up with this.
http://www.nbs-stl.com/CRX/Autocross%20 ... Circle.png
This plot is what is commonly known as the traction circle. The goal is to always have a racecar out on the edges of the circle. You can get lots more info on google.
This wall all done with about $20 to get Geez data coming in on the 3 ADC input pins and $125 to collect GPS data that comes in on the MAF input. The GPS comes from CanDooPro. Talk to Jeff if you contact them as he knows what he sent me. It is not a standard piece on there site.
Have fun tuning
Andy
Have fun tuning
Andy
This is really cool. Did you ever wonder where you spend most of your time in the VE Map. This happens to be 7 autocross runs with 3 different drivers. Data was collected in about 5 min of driving.
http://www.nbs-stl.com/CRX/Autocross%20 ... 20Time.png
The blue lines are where the motor passed thru the map.
Andy
Andy
I figured out how to overlay where The driver is on the brakes in red, on the gas in green and relatively coasting in white. White is not good.
http://www.nbs-stl.com/CRX/Autocross%20 ... 0Brake.png
If anyone wants to know how I did any of this, feel free to ask.
Andy
Andy
Here is something I never expected to find. From looking at lots of data off lots of different motors over the last 10 years, I have have learned that on most motor designs, MAPxRPM is essentially air flow. The only motors I have found that do not follow this model is ITB motors. This is the first motor that I have had this quantity of data to look at.
see http://www.nbs-stl.com/CRX/ITB%20MAPxRP ... 20RPMs.png
What I did is created 4 filters. In the first screen, you are only seeing data from 3900 to 4100. In the second screen is 4900 to 5100 RPM and so on.... The color is TPS angle over a narrow range of 10 to 28 degrees.
Notice that in the far left 4000 RPM screen, there is a distinct bend in the curve at right at 18% throttle. In the 7000 RPM data on the right, the transition happens at 28 degrees throttle angle.
These kinks in the graphs is when the motor transitions from acting like a Speed Density like tuned motor and moves to being more like a Alpha-N based motor. If your motor does not have these kinks, stay Speed Density. If it does do this, your intakes are coming alive at some point in the power range.
Lately, I have been playing with a new field that I call throttling. It is created in MLV and defined as
[TPS]<1.001?0:sqrt(sqrt([TPS]-1))*32
I am finding that it is a decent predictor of MAP bases on throttle position.
see http://www.nbs-stl.com/CRX/CRX%20Throttling.png
Have fun tuning
Andy
Have fun tuning
Andy
Here is a youtube video from the outside to get an idea of what the car sounds like on course.
https://www.youtube.com/watch?v=QWa8YQZkLR8
It has been running great. Here is a few logs off the car
http://www.nbs-stl.com/CRX/CRX%20Data.zip
Andy
Andy
I was testing a new tune in the driveway today. I got a solid 13000 RPM per Sec on a throttle stab. I am running Speed Density below 3500 RPM, and Alpha N above 3500 using table switching.
http://www.nbs-stl.com/CRX/CRX%20Thrott ... sponse.png
Andy
Andy
Here is the latest tune and the matching autocross data. Using Speed Density up to 3500 RPM and switching to Alpha-N above 3500 worked perfect. Unfortunately, we found the weak link of the motor when a rod cap left the crankcase. Looks like we are going to a B18C....
http://www.nbs-stl.com/CRX/CRX%20ITB%20Last%20Day.zip
Andy
Andy
Here is the new B18C motor that I installed in the car. I am shooting for 220HP at about 8900 RPM. The squirt will be controlling the VTec.
https://www.youtube.com/watch?v=MxBc5SPIMaM
Andy
Andy
