14 Point 7
14 Point 7
I am using a Spartan 2 WB O2 sensor/controller from 14Point7 with my MS2 v3.57. With the old version of TS3 I input a custom WB controller settings as per the feedback from the sensor on power up. Now with TS Ultra 14point7 is listed in the drop down menu. When I choose that from the custom menu in calibrate AFR, I no longer can input the custom settings. I feel that inputting the custom settings using the feed back numbers as more accurate. What is your recommendation?
64 Plymouth Savoy
MS2 3.57 Ver.3.4.0 from DIYAutoTune - 505 C.I. - Cross Ram dual FAST TBI - Tremec 5 SPD. - 36-1 Pick up - Batch Fire - Mopar Dist. MSD 6AL controlled by MS2 - Spartan 2 WBO2
Re: 14 Point 7
If you want to input your own values, then "Custom Linear WB' is still in the drop down. That will let you use your own values.
If you are just using the values that 14 Point 7 gave you, you might as well use the 14 Point 7 selection... Unless you were using tweaked values for some reason, then select Custom Linear WB
Re: 14 Point 7
I have noticed that using my 14point7 WBO2 (SLC-DIY1), that the values shown in TS are slightly leaner than what is shown on the SLC_DIY's display. Is the only way to adjust for this by using the custom linear WBO2 selection? I was using custom linear WBO2 previously. Would it be difficult to integrate some sort of offset ability for the WBO2 section? It seems that for the most part the offset is linear and could be easily corrected by allowing for some offset adjustment from within TS.
Tha Daily: 2005 Chevy Blazer
Re: 14 Point 7
I found the same issue using an Innovate - Bosch sensor. Had to use custom WB setting and tweek lower value to get data in TS to agree with gauge and Tuners O2. By tweeking one setting it is not a linear shift as would need to do both lower and upper values for straight offset.
Jimb
Jimb
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Re: 14 Point 7
It would be cool if, when 14point7 controller is chosen that TunerStudio then ran the sequencer code natively.
1983 Supercharged 3.2L Porsche 911 track car - Adaptronic
1976 3.0l twin-plug Porsche 911 autocrosser - TS v3.0.28 and MS2/Extra3.4.2
1971 2.7l Porsche 911 Targa S - Weber Carbs
Re: 14 Point 7
It isn't TS that you would want to do this differently. You need the MS to do that so it uses any improved values when TS isn't hooked up and then reports that value to TS.JohnJL wrote:It would be cool if, when 14point7 controller is chosen that TunerStudio then ran the sequencer code natively.
That is a significant architectural change though.
