More than a CAN gauge!
Suprazz
Post by Suprazz »
*** The gauge is now available ***
Latest pictures, info and order link: http://perfecttuning.pswebstore.com/en/ ... gauge.html
I would like to present you a new project I was working on for the last months. This will be a commercial product available in few weeks!
It's a new 52 mm (base, 66 mm overall), 1.7" Color, 24 multicolor LED, CAN bus, 3x analog inputs and more, universal gauge that will be available on the market very soon (and I'll take pre-orders)
The gauge fit in a 52 mm gauge pod and the overall diameter is 66 mm.
Here is the pictures of the PROTOTYPES version 1 and 2. The difference between the prototype and new version are:
- The new version will use a 1.7" OLED instead of a 1.5" OLED.
- The new version is slimmer
- New version doesnt have a connector on the back. There is wires going out and the connector will be inline for a cleaner look when installing without gage pod.
This is what the prototype version #1 look like:
And prototype version 2 and final version will look like:
All gauges will be made from billet aluminum and will be anodized black (or other colors on demand) for a very clean finish.
The gauge will be able to request data on the MS2 and MS3 over CAN bus. I plan to support other ECU later and OBDII too.
It will also include 3x protected generic 0-5v inputs. This gauge can be used without any standalone to display values of sensors connected to it.
Here is a list of sensors that will be compatible will this gauge:
- GM 3 bar MAP
- 150 PSI Oil/fuel sensor
- Temperature sensors like GM CLT, GM IAT.
- AFR sensors (Like the 14point7 wideband controller or the PerfectTuning that is using the Spartan 2 controller from 14point7).
- Flex fuel sensor (later)
- And more on request.
There is an ambient light sensor to automatically adjust display and led brightness
There is a digital input too.
And 1 pwm output to eventually use it as a boost controller.
There is 2 (hidden) buttons on each side to switch between screens and to configure the gauge.
The gauge is a Wifi hotspot so it's possible to configure it with your cellphone or laptop for the advanced configuration menus without installing any software.
There is actually few nice looking screens displaying multiple values at the same time.
The colors are configurable.
It can also be used as a shift Light.
I plan to also add configurable alarms (flashing (full led) with actual value to warn you).
The final retail price should be around 249USD when it will be released to market.
If you have any suggestions, other ideas or comment, please let me know!
Thanks!
nathaninwa
Re: More than a CAN gauge!
Post by nathaninwa »
Uhm, how cool is that. Nice work for sure and should look nice in the hole I'll have open soon :D
Broke4speed
Post by Broke4speed »
That's perfect! :D
1984 Volvo 244
MS2 v3.57
B6304S swap w/AW30-40e transmission.
Transmission controller made from a BASIC stamp & arcade joystick shifter
mrpham
Post by mrpham »
Interested in some production photos :)
Zaphod
Post by Zaphod »
+1
fun is not a straight line
Sven
Suprazz
Post by Suprazz »
Here is an update.
There was a big error on the version 2 so I changed few things and sent version 3 in production.
Here is a picture of the version 2 pcb.
I'm working on many things and I'll have more pictures soon!
nathaninwa
Very cool
Zaphod
Post by Zaphod »
Yeah baby... keep us updated! Very nice!
Sven
Sweeperstang
Post by Sweeperstang »
That looks cool.
Suprazz
Post by Suprazz »
Teaser shot of the final version with new billet aluminium enclosure without anodization... Final version will be anodized black.
Sticker is missing and cables on the back.
nathaninwa
I'm liking this setup. Will fit perfect in the dash of my drag car front and center
Broke4speed
I REALLY like this :).
1984 Volvo 244
MS2 v3.57
Zaphod
Post by Zaphod »
Do want!
Sven
Suprazz
Post by Suprazz »
Enclosure with black anodization. Pretty much final product!
nathaninwa
I do like the outcome
krisr
Post by krisr »
Can the outer LEDS be programmed to act as a shift light or anything like that?
Sydney, Australia
1971 Holden Monaro HQ
Suprazz
Post by Suprazz »
Yes, ill create an alarm module so youll be able to make the whole ring blink in different colors to let you know that there is something wrong. Shiftlight will be done like this.
Video and more pictures comming soon!
krisr
Post by krisr »
Awesome!
Sydney, Australia
Zaphod
Post by Zaphod »
So rad! Any idea what the prices will be like?
Sven
Suprazz
Post by Suprazz »
Around 250 USD for the gauge. I'll post all the info very soon
