TunerStudio log playback gauges?
When playing back a log in TS, is there a way to animate the gauges as if it was receiving the data from the ECU directly? I'd like to splice a dash playback together with audio/video recording to make it more obvious what's going on in a long log.
Re: TunerStudio log playback gauges?
I swear I did this before but recently I'm trying to figure out what I did and can't - so I'm curious too. Perhaps it was a dream before! lol
Either way it would be an awesome feature!
Mike
86 Capri 5.0 - PiMPxs w/ Coil on Plug conversion, 11.1 347 stroker, Solid roller, FRPP 60# inj. etc.
www.mikemartinelli.com
Nope... It is on the todo list, but 1st I wanted to add a different logging.
Currently the logs only contain a subset o the data and it has been converted to ascii. So TS would been to convert the ascii back to a value and then there would still potentially be dead gauges and indicators.
Now on the other side, adding a gauge cluster to MLV is another option where you would have gauge clusters that only have gauge that are in the log.
This would be nice.
