Dyno view log gauge
Zakari
Dyno view log gauge
Post by Zakari »
Hello,
I'm trying to recreate this view :
But cant find this gauge style (log viewer in a dash ?)
Ideally I'd like to view multiple signals in the same spot to spot discrepencies easily (just like the view of AFR vs TPSDot from AE on the bottom right).
How can this be achieved in TS ultra ?
Re: Dyno view log gauge
Post by LT401Vette »
It is the "Ling Graph" Style when in designer mode
Zakari
Post by Zakari »
Thank you for answering this.
I might be doing something wrong but I don't see that style of gauge in designer mode :
sschutte
Post by sschutte »
You are correct the line graph type gauge template is not available under to the current Add Gauges dialog. Try these steps as a workaround:
1) Create a Needle Bar Gauge
2) Right click gauge > Dashboard Designer > Gauge Style > Line Graph
3) Right click gauge > (select the output channel you want to display in the graph)
4) Fine tweak size and colors as needed
Zakari
Post by Zakari »
Aha this works thanks !
I'm guessing we dont have a feature yet to add multiple output on the same line graph ?
If we don't, could this be considered as a feature request ?
The dyno view is really useful when it comes to tuning static tables like spark or VE, but when tuning EAE on the dyno, I'd like to be able to plot MAP vs AFR while modifying EAE settings.
Again thanks for the help, it's already gonna make the tuning a lot easier.
WestfieldMX5
Post by WestfieldMX5 »
You can put several on top of each other.
Verzonden vanaf mijn iPhone met Tapatalk
