HELP! Composite logger, Toth Logger, etc DON'T WORK.
EnricGuardiaSinfreu
Post by EnricGuardiaSinfreu »
I get this:
"Empty read, No Data Received from Controller"
MSII V3.0 with a new msextra firmware. The rest works perfectly, I can get signal from MAP, TPS, thermistors (RPM on the way)...
It's really hard to sync RPM without that, I know I could do that manually with an oscilloscope but mine is quite slow using both channels.
Which can be the problem? Firmware? computer? cable? ms2 daughterboard?
Thanks!
slow_hemi6
Re: HELP! Composite logger, Toth Logger, etc DON'T WORK.
Post by slow_hemi6 »
Are you following the steps shown in the manual? http://www.msextra.com/doc/pdf/html/Meg ... 5-337.html
Cheers Luke
Post by LT401Vette »
If it is getting empty reads, the MS may not be seeing any signal for the crank. Pots?
EnricGuardiaSinfreu
Thanks, I solved this when I finally synchronized RPM
whittlebeast
Post by whittlebeast »
I was seeing that when I was chasing sync issues. Sometimes I would get nothing.
I still can't seen to get a MAP log. The pages never start piling up.
ANdy
EnricGuardiaSinfreu
whittlebeast wrote:I was seeing that when I was chasing sync issues. Sometimes I would get nothing.
ANdy
In the composite I only get RPM, CAM and sync loss. No TPS, no MAP, no O2...
idk
whittlebeast
A Composite log is a little funny to read. Post yours here.
Here is one off my car.
http://www.nbs-stl.com/CrxTypeR/40%20to ... %20log.csv
Andy
EnricGuardiaSinfreu wrote:In the composite I only get RPM, CAM and sync loss. No TPS, no MAP, no O2...
That's correct.
If you want a normal datalog, then go to Datalogging -> Start Datalogging
