Vvt, fuel and timing resolution
jsimmons
Post by jsimmons »
Any chance we could get some larger tables? Especially on the vvt tables? The 8x8 table for vvt on my coyote doesnt have enough resolution for the rpm im running and im having to make compromises on the table with such large rpm gaps. Same goes for fuel and ignition but is less of a problem. The issue is only going to get worse as i contiune to build on my combo and spin it up to 10k rpm eventually
Re: Vvt, fuel and timing resolution
Can you post a copy of the tune file you have now? A data log could also give a better idea if there are points where the resolution is hurting accuracy.
jsimmons
Post by jsimmons »
sure, ill email them to you matt.
Posting the files here in the thread would let the code team see them directly.
