Bosch L-jetronic sensor calibrations
I have a Datsun with L-jetronic efi i'm converting to ms2, should I use the Saab(bosch) setting for thermistor values? It seems to be the most logical choice
Re: Bosch L-jetronic sensor calibrations
You'll get a pretty easy check if those are correct. Both IAT and CTS will read ambient with the engine cold.Spiffy wrote:I have a Datsun with L-jetronic efi i'm converting to ms2, should I use the Saab(bosch) setting for thermistor values? It seems to be the most logical choice
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
I tried today but got this message, any idea as to why?
I get the same faultmessage on clt, iat and wideband sensor calibration
How are you connected?
BluetoothLT401Vette wrote:How are you connected?
Sent fra min HUAWEI VNS-L31 via Tapatalk
That is what I was wondering... I had someone else get a similar error when they were using Bluetooth as a virtual com port.
Try it using Bluetooth direct. The comm timings with bluetooth direct are adjusted for Bluetooth.
Forgive me my ignorance but where do I find that setting? I only have tunerstudio lite at the moment do I need the registered version or is this a Windows setting?LT401Vette wrote:That is what I was wondering... I had someone else get a similar error when they were using Bluetooth as a virtual com port.
It used to be only in the registered edition, but with 3.0.20 D2XX and Bluetooth Direct have been added to the Lite Edition as well.
So update and then you will see Bluetooth Direct in Communication Settings.
Thank you, I can see it now
Will try out when I get back home next week!
It works now. Problem solved, thanks for the help
