Bosch L-jetronic sensor calibrations
Spiffy
Post by Spiffy »
I have a Datsun with L-jetronic efi i'm converting to ms2, should I use the Saab(bosch) setting for thermistor values? It seems to be the most logical choice
DaveEFI
Re: Bosch L-jetronic sensor calibrations
Post by DaveEFI »
Spiffy wrote:I have a Datsun with L-jetronic efi i'm converting to ms2, should I use the Saab(bosch) setting for thermistor values? It seems to be the most logical choice
You'll get a pretty easy check if those are correct. Both IAT and CTS will read ambient with the engine cold.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
Spiffy
Post by Spiffy »
I tried today but got this message, any idea as to why?
I get the same faultmessage on clt, iat and wideband sensor calibration Image
Post by LT401Vette »
How are you connected?
Spiffy
Post by Spiffy »
LT401Vette wrote:How are you connected?
Bluetooth
Sent fra min HUAWEI VNS-L31 via Tapatalk
That is what I was wondering... I had someone else get a similar error when they were using Bluetooth as a virtual com port.
Try it using Bluetooth direct. The comm timings with bluetooth direct are adjusted for Bluetooth.
Spiffy
Post by Spiffy »
LT401Vette wrote:That is what I was wondering... I had someone else get a similar error when they were using Bluetooth as a virtual com port.
Forgive me my ignorance but where do I find that setting? I only have tunerstudio lite at the moment do I need the registered version or is this a Windows setting?
It used to be only in the registered edition, but with 3.0.20 D2XX and Bluetooth Direct have been added to the Lite Edition as well.
So update and then you will see Bluetooth Direct in Communication Settings.
Spiffy
Post by Spiffy »
Thank you, I can see it now :)
Will try out when I get back home next week! 8)
Spiffy
Post by Spiffy »
It works now. Problem solved, thanks for the help
