Voltage not reading correct afr
maych87
Post by maych87 »
I am using my jimstim to test some outputs. I noticed that my wideband o2 voltage seems off. So I checked it. At 0v it should read 10 afr. It reads 10.1afr. Is that normal. If not how do I correct this. Attached is a picture of the calibrate afr table, afr gauge and exhaust gas oxygen voltage. As you can see it's set to 0v and is reading 10.1 afr.
Re: Voltage not reading correct afr
Post by racingmini_mtl »
That's an artifact of the lag factor computation. If you set the Lambda lag factor to 100 (no smoothing), you will have the correct 10.0 at 0V. But you may then have a significant amount of noise on the AFR value.
maych87
Post by maych87 »
Does smoothing only affect the gauge reading? Or does it also affect how the reading is interpreted in the fuel tables?
It affects everything.
maych87
Post by maych87 »
That does not give you a bad tune on the fuel tables? Is there a recommended lambda lag factor to set it to?
