Boost control target table
Postby theduck » Sat Apr 29, 2017 7:16 am
Quick question. Are the boost control target table figures in kpa or psi?
Ford Pinto (Euro 4cyl 2.0l SOHC) with TF035 Turbocharger - Now powered by MS2 V3.0 running MS2/Extra 3.4.2.
theduck
Re: Boost control target table
Postby Dennis930 » Sat Apr 29, 2017 7:27 am
The units are KPA.
Porsche 930 3.0 Slantnose
MS3/MS3X Sequential Injection & Spark, MS Knock, Dual plug, LS2 coils, Siemens 55 lb/hr HiZ injectors, ALM-ADV Wide Band,
Carrera Intake, Extrude honed, Ford 70mm Throttlebody, GTX3071R Turbo
Dennis930
Postby theduck » Sat Apr 29, 2017 7:35 am
Hmmm that's what I thought. Just tried it for the first time and had 50 in all the boxes but it went wel over that to more like 150kpa of boost.
theduck
Postby theduck » Sat Apr 29, 2017 8:22 am
Have had a play around with the settings and seems to be something else wrong as no matter what target etc I set it still overboosts. With no power to the valve I get wastegate pressure but as soon as I add power it overboosts
theduck
Postby nathaninwa » Sat Apr 29, 2017 8:31 pm
Post a tune file and datalog
Volvo 940, 2jzgte, MS3Pro, 815/692 @ 27psi.
240z, LS3 MS3pro/micro I/O 8.28@173
86 454/4l80e, ms3pro/micro. Tow rig
nathaninwa
Postby Dennis930 » Sun Apr 30, 2017 10:12 am
The values in the table are absolute, so you have at add 101kpa to your desired boost level. So, if your target is 120kpa (about 17psi), the table values would be 220kpa.
Dennis930
Postby Dennis930 » Sun Apr 30, 2017 10:16 am
How is your valve plumbed? With no DC being sent to the valve it should be venting the top of the wastegate. As DC is applied it should be applying boost pressure to the top of the wastegate.
Dennis930
Postby theduck » Wed May 03, 2017 3:58 am
Sorry was away for the bank holiday and now off work unwell. I am using a 3 port MAC valve plumbed to an internal wastegate so the 3rd port is open to atmosphere. With no power to the valve it is correctly venting to the top of the wastegate. With power applied to the valve it is only venting to atmosphere, seemingly no matter what settings I use. I havent got my latest version of the tune on this laptop but the boost controller settings on the attached are the same as I have in the car.
Boostcontroller settings.msq
(119.61 KiB) Downloaded 16 times
theduck
Postby franksidebike » Wed May 03, 2017 10:55 am
Hi
Your Boost settings are incorrect.
"Maximum Boost (kpa)" = 100kpa is sea Level, no Boost!
"Boost Control Target Tabel" = 50 is cruising!
Please start in Open Loop and understand the Settings!
Frank
franksidebike
Postby theduck » Wed May 03, 2017 12:30 pm
I realise that from one of the earlier posts, not had opportunity to try it since. Will test in open loop and go from there.
theduck
Return to Tuner Studio
Users browsing this forum: No registered users and 4 guests
