semi-sequential wont go over 1600rpm. skip to p2
TheMU47
Post by TheMU47 »
MS3X pre-assembled. 3.57. TS v 3.0.22, running the latest 1.5.0
My truck will not start. In test mode, the spark is good, injectors clicking. When cranking, I have no spark or fuel. This on LSJ Ecotec engine. GM 4x cam, 60-2 crank set at 120* btdc angle. During cranking, tuner studio shows cam and crank synced. Currently set at full sequential, poll level.
I am new to MS and tuner studio, but a quick study.
Laptop is next to me if you would like to hear any of the settings.
If it works normally in test mode, why is it not working while cranking?
Any help greatly appreciated.
Build 'em, Break 'em, Build 'em again.
turbo LSJ swapped S-10
Re: sequential no start on GM. 3.57 / 1.5.0 / MS3X
Post by LT401Vette »
:msq:
TheMU47
Post by TheMU47 »
here's the msq. not sure what good a few seconds of cranking will do for logging. I'll log it if you need it.
MSQ attached
TheMU47
Post by TheMU47 »
switched to wasted COP and semi-sequential, still nothing. here's the msq and datalog of start attempt.
I could really use a hand here. It took two years to finish this truck, and it all comes down to squat if it doesn't F'n run.
Thanks.
billr
Post by billr »
That CSV file is empty. Regardless, we need regular run log (MSL); and maybe a "tooth log" would help, too. Yes, even a few seconds of logging can be useful.
I gotta ask... have you checked ignition timing with a light, while cranking? If you have no spark (while cranking), you can't have any confidence about that "tooth #1 angle" yet.
TheMU47
Post by TheMU47 »
well, I had removed the crank position sensor, and counted the teeth back to the sync (missing teeth) and counted 20 teeth. So it should be 120*.
I'll get another log. Still trying to figure out how this program works.
I have not put a timing light on it. I don't have one.
whittlebeast
Post by whittlebeast »
You need a timing light.
TheMU47
Post by TheMU47 »
attached MSL log with tooth logger running. Well, if i did it right that is.
file too big. Tried a shorter log.
TheMU47
Post by TheMU47 »
that's odd. I just checked the log and its showing no rpm, but the gauge on dash mode shows 300ish rpm.
billr
Post by billr »
Was the engine cranking during that MSL? The "battery voltage" never dropped, that always happens when the engine is cranking. What kind of CKP sensor (VR or Hall), and how do you have the pots for it set? Counting the tooth offset physically can (and often, for me) get confusing. Rely only on the timing light to set the tooth #1 offset. You are going to want a light anyway, to confirm timing is OK all the way through the rpm range and other troubleshooting procedures.
TheMU47
Post by TheMU47 »
yes, it was cranking. I had a battery charger on it.
VR crank sensor (two wire) on 60-2
I don't know what you mean by "pots"
ok, I'll pick up a timing light this weekend.
TheMU47
Post by TheMU47 »
here's another MSL file. I hope this helps. Shows RPM anyway
whittlebeast
The code is not set up correctly to match the signal that the crank/crank sensor is sending.
TheMU47
Post by TheMU47 »
so you see something wrong? excellent. Steer me in the right direction please.
whittlebeast
What I am seeing is a repeating lost sync error. I do not know the specifics of your motor.
TheMU47
Post by TheMU47 »
I know some of the specifics of the engine. This is a 2007 Chevy Cobalt SS LSJ (supercharged 2.0L) engine.
right now I have it on semi-sequential, so cam signal (gm 4x) should not be in use right now. I could switch back to full sequential. Unless you mean something else is out of sync.
billr
Post by billr »
"The code is not set up correctly to match the signal that the crank/crank sensor is sending."
I'm confused by that. The OP says it is a 60-2 wheel (58X?), and that is what is set in TS; with wasted COP. That is certainly in the FW code.
OP, was the battery charger still there for the most recent log? Just curious, because that recent one clearly shows cranking and a whole lot of sync loss. There is no surprise about the sync loss if you have no clue what the "pots" are. On the mainboard are two potentiometers, R52 and R56, that have a little screw to adjust them. For a VR CKP sensor those pot screws should be turned CCW until you feel o hear a "clicking" from inside them. Seven turns should be enough, but I tend to go 15-20, more turns won't hurt anything as that "click" is a little clutch that releases when the pot hits the end of its range. Obviously, the manual explain all this better.
TheMU47
Post by TheMU47 »
the last log did not have the charger hooked up. Should see voltage drop.
I had no idea about the potentiometers on the main board. I'll pull the box and turn them CCW.
TheMU47
Post by TheMU47 »
new MSL file. no battery charger. Pots turned CCW
billr
Post by billr »
Post a tooth log, now that the pots are set full CCW. Both the MAT and TPS are looking strange, and both are on the 5V ref, so real soon we will need to dig into that. But right now I want to see if you now have a decent CKP signal.
