Injector size
maych87
Injector size
Post by maych87 »
I have a 1989 Porsche 911 with a 3.6 l. I am setting up the injector size in tuner studio. Porsche runs a much higher fuel pressure than 43.5 psi that most injectors are flow tested at. Do I use my injector flow rating at 43.5 psi or what they are rated at for my vehicles fuel pressure?
Sent from my iPhone using Tapatalk Pro
grom_e30
Re: Injector size
Post by grom_e30 »
the flow rate they will be at in your install.
maych87
Re: Injector size
Post by maych87 »
The manual says 55psi engine off pump running. And 48psi engine at idle. Which is the proper psi to use?
DaveEFI
Re: Injector size
Post by DaveEFI »
You use the higher one. That is the pressure at full throttle.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
