Relay Strategy
Click here to enter
Contact a Forum Administrator
Raymond_B
Relay Strategy
Post by Raymond_B »
I know in the manual it recommends running several items off a single fuel pump relay for safety's sake. I.E coils, fuel pump, injectors, and O2 sensor (for sensor life). But is it also safe to run multiple relays off the single fuel pump enable trigger wire? I ask because I am going to run a good sized fuel pump (Weldon DB2025-A) and 8 IGN-1A coils so both setups require a pretty good amount of current. I guess I could run one really large fuel pump relay, but I am also thinking about running 3 smaller relays. 1 for the coils, 1 for the fuel pump, and then 1 for the injectors and O2 sensor and splitting the fuel pump enable trigger to each.
Does that make sense? What are you guys doing?
http://www.buildpics.org/
billr
Re: Relay Strategy
Post by billr »
It all depends on the current draw of the relays. You can connect as many as you want to the FP output, as long as their combined draw doesn't exceed the limit for that output. The same applies to a single "really large" relay, if it has a "really large" coil that draws too much current, then that will gain you nothing. Relays are available in a wide range of combinations of coil power, rated voltage, rated current, pull-in/drop-out voltage, cycle life, size, cost, etc. You need to pore through the specs and settle on the parameters that are most important to you.
You could, of course, put a relay between the FP output and all the rest of them...
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
Right, exactly. Isn't the fuel pump enable a ground switch? So there's nothing to exceed right?
slow_hemi6
Re: Relay Strategy
Post by slow_hemi6 »
Current is a constant through all parts of a series circuit. Of course the driver carries current and it has a limit.
Cheers Luke
LAV1000
Re: Relay Strategy
Post by LAV1000 »
billr wrote: You could, of course, put a relay between the FP output and all the rest of them...
That is one way to do it.
This way you need an extra relay, but each one has its own single job, easy on fault finding.
Can be the same type which is used in OEM istalls to drive, lights, ignition coils, fuel pump.
Second way, just drive one of the relays from the FP output.
And use the output contact of this relay to connect to the coils of the other ones.
This way you have one relay whit two functions, more difficult on fault finding.
On this one I would use the fuel pump relay, but thats my mind trying to be logical :D
And check if the MS output is up to it to drive the needed current.
DaveEFI
Re: Relay Strategy
Post by DaveEFI »
Raymond_B wrote:I know in the manual it recommends running several items off a single fuel pump relay for safety's sake. I.E coils, fuel pump, injectors, and O2 sensor (for sensor life). But is it also safe to run multiple relays off the single fuel pump enable trigger wire? I ask because I am going to run a good sized fuel pump (Weldon DB2025-A) and 8 IGN-1A coils so both setups require a pretty good amount of current. I guess I could run one really large fuel pump relay, but I am also thinking about running 3 smaller relays. 1 for the coils, 1 for the fuel pump, and then 1 for the injectors and O2 sensor and splitting the fuel pump enable trigger to each.
You could feed your extra relay coils from the pump high current circuit. And avoid any extra load to the MS pump driver. Use a series diode to feed each one of those extra relay coils to prevent any possibility of interaction between them.
The MS pump driver circuit is nominally 1 amp peak load.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
Looking around for a diagram to understand this all better I found this. Seems pretty straightforward?
http://www.msextra.com/forums/viewtopic ... 31&t=55597
LAV1000
Re: Relay Strategy
Post by LAV1000 »
Raymond_B wrote:Looking around for a diagram to understand this all better I found this. Seems pretty straightforward?
This is the/my second way.
remark: Put a fuse for each load in the battery line !!
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
Yes, absolutely! Thank you.
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
OK, sat down with DipTrace and worked this out. This isolates the MS to it's own relay and a single accessory relay that triggers all other relays.
Any mistakes or misunderstandings?
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
Also thinking about running the fuel pump trigger from the Megasquirt through the Ford fuel pump inertia switch. That way in an impact the fuel pump, coils, O2, and injectors would shutdown.
LAV1000
Re: Relay Strategy
Post by LAV1000 »
That seems almost alright to me, inertia switch is also good option.
Remark on the fuses, put them between +12V and the relay contact.
This way relay contacts are also protected and there is less unfused wire (between battery and fuse).
And it is easier on checking fuses, your relais don't need to be activated to check them.
Remember, first function of a fuse is to protect wire and avoiding fire, you dont want that in any car or motorcycle.
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
LAV1000 wrote:That seems almost alright to me, inertia switch is also good option.
Sounds logical, I was just copying the manual and it had the fuses post relays, but pre does make sense.
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
What better way to spend your lunch hour than cleaning up your relay layout :) Originally I had wanted to run everything through the Bussman panel, but it can only be wired for all pos or all neg switched relays. Also the smallish connectors did not support a 40A relay which I will be using for my IGN-1A coils. So the coils and neg switched "Accessory" relay are separate. In addition I had two big Tyco relays that came with the e-fans I purchsed so I will use those as well.
LAV1000
Re: Relay Strategy
Post by LAV1000 »
Can pin 6 handle 2 relays ?
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
LAV1000 wrote:Can pin 6 handle 2 relays ?
Darn good question, that's my "electrical newbness" showing again. Because it's ground switched I just tied them together, I'll double check. Thank you for the sharp eye!
On edit: Looking at the manual pin 6 on MS3X is 3 amp.
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
Probably going to mess this up, but if I use the formula of P=I/V and flip it around to I=P/V
Then I=3.9watts (the rated coil power of the relay I am using)/12VDC = 0.325A Does this make sense or have I horribly failed at maths and or electronics?
LAV1000
Re: Relay Strategy
Post by LAV1000 »
those 3 Amps should be enough to drive the two relays.
And; P(Watt)= I(Amps) x U(Volts) >>> I=P/U
In a Ideal world this would work but coils of relays act a bit different and have a Inrush current.
But its no problem on this set up
Raymond_B
Re: Relay Strategy
Post by Raymond_B »
LAV1000 wrote:those 3 Amps should be enough to drive the two relays.
Much appreciated, thank you!
