Base tune needed for BMW M42 & M44 engines
I would like to compare base tunes for M42 and M44 engines. I currently have a M44 block and M42 head with a DASC supercharger and trying to sort out startup/idle issues.
Can anyone send me a base tune for m42 and m44 engines?
Re: Base tune needed for BMW M42 & M44 engines
Bit of a long shot, but did you ever find the base maps?
Hi guys,
I have base map for m42 engine if you are still looking for it. It is not dyno-tuned but it is driveable.
I am interested in base tunes for either m44 or m42 with a dasc. I will be using #42 lb. injectors and the 7-8 psi pulley.
Hi I am interested in base ms2 map for m44 or m42.
Thanks!
Thanks!
PM sentGiljavier wrote:Hi I am interested in base ms2 map for m44 or m42.
Thanks!
Hello, do you still have the base map? Can you send me?Pan Dodo wrote:Hi guys,
I would also love to get a copy of the m42 base map if possible? thanks!
under construction .M42 trottle bodies , schrick cams . runs .
- Attachments
- 2019-10-05_07.56.21.msq
- (178.49 KiB) Downloaded 675 times
Bmw M535 lpg
Bmw 2002
VW bus 2.2 subaru
MS2extra
Bmw 2002
VW bus 2.2 subaru
MS2extra
Hi im also looking for a base tune for m42 if anyone can help out thanks.
I seek a Base map for the M44. I have my E36 318is running, but it's very smoky. The AFR heads down to 10 in about 15 seconds, then I stall out. A tune to compare with mine would be great! thanks, Simon
I am also looking for a basemap for an m42 as I don't have a lambda sensor working yet. Does anyone have one? I would REALLY appreciate!!
Your system is not yet complete.
Get the Lambda system up and running before you try to run it.
Much more satisfying...
MS/TunerStudio provides default tables that I have never had problems with.
Plugging in someone else's tune is like juggling a live grenade. Will your garage burn along with your car?
Re: Se necesita una sintonía base para los motores BMW M42 y M44
también me encantaría obtener una copia del mapa base m42/m44 si es posible. ¡Gracias!
