What's needed to enable the fuel injector ve trim tables? On my V8 Ford the outer 4 holes run richer than the inner 4 holes. I have channel 1 wired to 1,4,5,8 and 2,3,7,6 to channel 2. Ive sorted a work around by setting the ecu to simi-sequential and only use 2 channels. The require fuel value ends up quite small but it's working. Just wondering what's needed to enable trims when only using 2 fuel channels.
Thanks Ryan
untimed batch fire vetrim tables
Re: untimed batch fire vetrim tables
So just what i did then. Switching to simi-sequential really messes with the required fuel value to get it running right. Would be nice to have untimed with channel trims.
