Would it possible to show the name of the .table-file that (if so) has been loaded in the ignition table-window?
Also, provided no cells have been changed since the previously saved table-file was loaded.
When even one cell is changed, the filename should disappear from the window (or maybe "-altered" or "-Modified" could be added) as it's not valid anymore, that is, until the table is saved again and its filename should reappear again in the window.
Reasoning:
Working with 2 tables (IGN table1 and IGN table3), I sometimes get confused which table is currently in use, and have then to take screenshots of TS ignition tables to compare with earlier saved tables on file.
For instance;
FR: show filename of loaded file in table-windows
Re: FR: show filename of loaded file in table-windows
Anything is possible...
It is an interesting idea.
