Noise in Cam and Crank Signal
okubricko
Post by okubricko »
I edited the title of this post to more reflect where things are now with my build. I didn't want to start a new thread. See the last few posts.
Hey all, thanks for looking at this. I have my MS3X in my vehicle and am at the point where I'm running my first tests of the Tooth and Composite Logger. The pictures below are my output. I think that they look like they should but wanted to get extra eyes on it. I'm running a 36-1 crank trigger with a single tooth cam trigger on a four cylinder engine. In the composite logger I can see some sync errors at first but then they disappear and don't show up after those initial blips. The crank signal looks good, uniform and show the engine compressions. The single tooth cam signal is also showing. My question on this is should that signal look like a single point of a wave?
Below is the tooth logger. To me this also looks correct. Single long line for the missing tooth and then the compression cycles.
Any input would be appreciated. Thanks again.
Re: Confirmation before Proceeding
All looks ok to me.
okubricko
Post by okubricko »
thanks much James
okubricko
Post by okubricko »
So after doing all the pre-start checks in the manual before cranking I didn't get it to fire, just pops and cranking. I did a quick composite log and get this.
Am I getting interference or battery voltage drop? I am guessing some interference due to the extra cam signal. I'll check to make sure the crank sensor hasn't shifted. Just looking for other opinions.
billr
Post by billr »
Post a tooth-log from an actual starting attempt as well as...
:msq:
okubricko
Post by okubricko »
Attached are two tooth logger pictures. The first one picture is the initial start of cranking which looks good, but then the signal goes haywire.
MSQ as well.
Betty - CurrentTune.msq
okubricko
Re: Noise in Cam and Crank Signal
Post by okubricko »
I'm wondering if this is a voltage issue. I have a 14point7 O2 gauge that had a backlit LCD screen. When I crank the engine I notice that the backlight on the screen goes on and off. I'm guessing the voltage drop is causing the interference.
billr
Post by billr »
Well, hard to say without the MSL (datalog) file...
:msq:
Exidous
Post by Exidous »
Many position sensors are tolerant of voltage drops as is the MS series. They'll usually still work down to about 6volts. If you were lower than that I doubt you'd even be able to crank.
I know that doesn't help much but at least you can possibly rule out the voltage.
okubricko
Post by okubricko »
Sorry, here is the MSL.
2017-09-03_17.44.19 - Noise.msl
billr
Post by billr »
Well, battery voltage is only falling to 9.8; that should be OK.
What kind of crank/cam sensors (VR, Hall, other)? If Hall, what voltage is the supply, what pull-up resistance to what voltage? All wiring for those sensors is shielded, with the shield grounded at only the MS end? Is any wiring shared by both the CKP and CMP sensors?
okubricko
Post by okubricko »
Sorry for the delay in getting back to this, I was out of town. The Crank sensor is a VR, Cam is a Hall. The VR is shielded per the manual, I need to check to see if it's grounded at the sensor because I have it grounded at the MS3X. Although, I tried disconnecting the ground at the MS3X but still got the same noise in the signal. The Hall cam sensor is aftermarket and is powered with a +12v supply and has a built in internal pull up resistor. It's designed to be used with megasquirt.
Quick question, I've read this both ways. Does a Hall Cam sensor need to have JP7 jumpered or no?
There is shared wiring. I used a terminal block and ran all the sensor grounds to it and then I have one lead off the the terminal block run to pin 7 on the MS3X. Grounded at Pin 7 on MS3X - IAT, CLT, OS, Cam, Crank, O2, LS2 Coil sensor grounds, Flex Fuel. Should I only have actual sensors grounded at pin 7 and utilize the other ground points on the MS3X for things like O2, LS2 Coils?
I was just looking at the manual and the Flex Fuel sensor should probably be grounded to the engine and not the MS3X. I'll have to move that over.
I have done the same for everything that needs +12v. Power from the relay goes to a single point and then is distributed to all the individual sensors and outputs that need +12v. LS2 Coils, Injectors, Idle Valve, Flex Fuel.
I think in the meantime while I'm waiting for words of wisdom from here I'll start by disconnecting everything except the Crank and Cam, try cranking and see what happens. If no noise, I'll slowly add things one by one and see when the noise appears. I'll also make sure that the Flex Fuel sensor doesn't go to sensor ground.
Thanks.
billr
Post by billr »
If the Hall sensor has a built-in pull-up, I would removed the jumper at JP7 on the MS3X.
okubricko
Post by okubricko »
I thought I'd come back to this thread and wrap it up in case anyone else has a problem like this.
The sync loss was coming from a weak battery. My signal would be great at first and then degrade. I replaced the battery and have eliminated all problems.
