installed table switching hardware and now lean off throttle
i got the table switching working fine it seems by the way it runs and the dashboard icon lights up on msdroid saying it is switched
now i have a strange very lean spot when off throttle or just at the lightest cruise
i will get a picture of the wiring soon
trying to add my msdroid tune for review
2002 Montero dakar rig
FORD 3.0L DOHC duratec / 6HP26
gt3582 boost to the moon
Ms3X running and making fire!
dodge M37 look-a-like 1 ton
4.2l chevy atlas / 6R80
66mm turbocharger ~8#
Ms3X sequential finally kicking some butt
Re: installed table switching hardware and now lean off thro
not sure if drop box got the right one
this is for sure though....
is there a way to attach the cranking and start enrichment stuff with the fuel and spark tables?
If I'm understanding, you;re saying you have a lean spot when table-switched? For the fact that both VE1 and VE3 are largely the same, compare from 500-2200 rpm, up to 50kpa. VE3 is a bit leaner there than VE1.turbothis wrote:i got the table switching working fine it seems by the way it runs and the dashboard icon lights up on msdroid saying it is switched
-Dave
'70 Chevelle ZZ383/700r4/3.73 MS3X, 36-1, LS Coils, Holley Stealthram -- success story
'92 Saturn 1.9 DOHC/5sp, MS3, Champcar racer success story
'79 Malibu DartSHP400/80mm/PG/3.55, MS3X/36-1/LS Coils -- success story
Porsche 944 S2 3.0 -- MS3X/36-1/LS Coils, 1:44s Mid-Ohio, Pro Course
since i started the table switch i have only ran ve1 which is my E85 tune
it was nasty great before table switching
power side is still solid but has a crazy lean cruise and slightly under throtttle setting
i will get a log of this today and after that unwire it to see if it goes away.....
thanks for the reply
ok here is a log of the lean ness
i turned off the fuel and spark table switching and the lean is the same
next i will unsolder the leads inside the box to see if that is the issue
for reference V1 is E85 and VE3 is super unleaded
maybe my wiring is bad?
5v from led17 resistor (black wire)
diodes are oriented correctly i think (both black wires are the switch)
0v from db9 pin 9 i believe
man, i removed the table switch hardware and it remains a lean phantom
i swear it was not like this before i wired in the parts
i guess i will load the original 1 table E85 tune ( i swear was good) and see about tuning out the lean phantom if it is in there too?
-Dave
i did some initial autotuning with tunerstudios on my laptop (WIN7)
then i watch the gauges of things on my tablet (android)
somewhere in there the load tune or update controller or one of the super fancy options i choice poorly or something
now i can solder up the table switch stuff again and just continue the tuning
sorry for the waste and thanks for the help
