Polling CAN data
MolsonB
Polling CAN data
Post by MolsonB »
Hi guys, I have my own CAN setup on a Teensy board, and I can receive all the broadcasting fine (1520 base). But I can't seem to get any polling request from MS3, or if I send a Msg_Req, I don't get a Msg_Rsp back.
For example, trying to set the RTC.
I set Enable Real Time Clock to CAN, and for compatibility reasons I picked the same as JBPerf. Table is 7 and offset is 110.
The only CAN messages I receive, are just the broadcasting ones and not any MSG_REQ to send the new time.
Is there a setting I'm missing? I even enabled ADC polling and turned on a few, but no requests show up.
Reading the Can Protocol PDF, I tried to fetch the RPM, and didn't receive anything back. Not sure what I'm doing wrong.
MS3 pre-1.5.1 beta 7
*Looking into things more, do I have to get complicated and create my own Can Device under Project Properties with an .ini file?
grom_e30
Re: Polling CAN data
Post by grom_e30 »
no need to add a can device with an ini. is your teensy masking 29bit headers? maybe post the teensy code and a msq file for the ecu.
Manu
Post by Manu »
Hello,
With the recent flexcan librairie, you have to set mailboxes to use extended CAN. There are posts about this at pjrc forum.
Regards,
Manu
https://www.megasquirt.fr
MolsonB
Post by MolsonB »
Thank you both, it looks like it was the 29bit / extended problem. I'm not using classes and sticking to the polling.
I had to add the filters in my 'Setup'.
Code: Select all
static CAN_message_t txmsg, rxmsg;
void setup(void) {
Can0.begin(500000);
CAN_filter_t allPassFilter;
  allPassFilter.id=0;
  allPassFilter.ext=1;
  allPassFilter.rtr=0;
  //leave the first 4 mailboxes to use the default filter. Just change the higher ones
  for (uint8_t filterNum = 4; filterNum < 16;filterNum++){
    Can0.setFilter(allPassFilter,filterNum);
void loop(void) {
  if (Can0.read(rxmsg))  ..........
