Issue compare tune with version 3.0.50.06
Suprazz
Post by Suprazz »
I have a lot of issue with the latest version of tuner studio.
I'm on my bench test and I want to reload different tunes and tunerstudio pop-up the compare tool. WHen I press send tuner settings most of the time it keep failing and popping the compare tune menu again.
if I close everything and I'm able to load the tune and test the ecu. Everything is fine.
If I power cycle the ecu, the tune compare can pop up again with odd parameters (while everything was fine just before the power cycle and no parameters changed)..
Re: Issue compare tune with version 3.0.50.06
Post by LT401Vette »
The beta 3.0.50.06 is the 1st that is truly from the beta branch, not just a stable front runner.
There is an issue with sending a burning some settings in the wrong order. It can take a couple sends in cases.
It is not a problem with the difference reports, they are what saves the settings from getting lost. So keep that on and there will be a beta update shortly.
