Stepper IAC wiring - pin 29 missing
Re: Stepper IAC wiring - pin 29 missing
well I pulled the ecu since I obviously missed something. I admit to not reading carefully , and found Q16 -finally-and yes it is jumpered . I took a pic but for some reason I am having trouble uploading-(board attachment has been reached?)
So I just unsoldered it.
Steve
1971 Datsun 240z 3.2 L6 1975 EFI intake plenum 60mmTB with 42lb Bosch injectors
MS3x 3.57 Ignition LS1 coils running full sequential
!983 Nissan 720 MS2/3.57 ported efi 26lb Bosch VW 4 tower ignition wasted spark
Well reassembled everything and still the same results on the voltage tests and running tests. So have I disconnected something I shouldn't have ?
Steve
I'm short on time, but have a quick question: did you send several commands to the IAC and see all but pin 36 toggle from 0-12V; is pin 36 the only one that is "stuck" at 12V?
Okay-so just now tested and have
1a-0v
1b-12
2a-0v
36-12v
and to be sure -this is testing wires UNATTACHED from the stepper and using separate ground. Changing commands changed nothing.
Checking voltages while wired to stepper I got
1a-10.3v
1b-10.3v
2a-5.5v
36-5.5v
1a-0v
1b-12
2a-0v
36-12v
1a-10.3v
1b-10.3v
2a-5.5v
36-5.5v
Steve
The best way to test is to turn off Idle Control and use the output test mode to manually turn IAC1 on/off and IAC2 on/off. That way you can be sure what the outputs should be doing without short "steps" confusing you.
Turn off idle control? You mean select "none" under Idle control? Then you wouldn't have a test mode available .
Steve
Yes you would.Madkaw wrote:Turn off idle control? You mean select "none" under Idle control? Then you wouldn't have a test mode available .
Let me make sure I am understanding this.
To turn off idle control I need to select none as far as idle valve. Then your asking me to go to test modes and test the outputs using the idle valve output test( which is not available if I have selected none for idle valve)
I'm confused.
I'm confused.
Steve
Okay- I searched and figured out what to do to test outputs. I'll let you know
Steve
So I used the I/O output tests and powered up IAC1 and IAC2 and took voltage readings. I used the chassis as ground. I checked battery voltage and it was low at 11.97v's-time to charge it up I guess.
IAC 1
1A-11v
1B-0v
2A(36 pin)-0v
2B-11v
IAC2
1A-0v
1B-11v
2A-0v
2B-0v
IAC 1
1A-11v
1B-0v
2A(36 pin)-0v
2B-11v
IAC2
1A-0v
1B-11v
2A-0v
2B-0v
Steve
Seems that your 2A output is either not connected or broken.
Try repeating the test on that output with your voltmeter between battery +ve and 2A.
Again, I can't use the pictures posted to check how the mainboard was modified to route 2a out through pin 36 instead of pin 29. Has anybody else verified that all looks OK there?
OP, are you sure Q16 has been disconnected from pin 36?
There was no modification done to pin36 to route instead of 29. I took literally that I could JUST USE pin 36 as I posted earlier. I made sure there was no jumper attached to Q16 -so is this my issue?billr wrote:Again, I can't use the pictures posted to check how the mainboard was modified to route 2a out through pin 36 instead of pin 29. Has anybody else verified that all looks OK there?
Steve
Well yes, you haven't connected it to anything.Madkaw wrote:There was no modification done to pin36 to route instead of 29. I took literally that I could JUST USE pin 36 as I posted earlier. I made sure there was no jumper attached to Q16 -so is this my issue?billr wrote:Again, I can't use the pictures posted to check how the mainboard was modified to route 2a out through pin 36 instead of pin 29. Has anybody else verified that all looks OK there?
Inside the case you need pin36 to connect to IAC2A.
I guess I took this too literal-billr wrote:Use pin 36 that was reserved for the single-coil ignition driver.
Steve
Okay-so I'm on the same page now as far as what to do, but now its about HOW to do.
So how to connect pin 36 to 2A? I see 2a has a jumper wire on the CB -do I disconnect the other end and jumper it over to q16 ?
Steve
See here:
http://www.msextra.com/doc/pdf/html/MS3 ... e-1.4.html
There's an image of the reverse side of the board with the jumper wires from the processor to the connector.
At the connector end (left), remove the wire that was going to pin 29 (2A) and reconnect it so the signal goes out through pin 36 instead. You may need to extend it.
James,
I see 2a coming from the processor. I understand I need to un solder from connector end. I need to reconnect to pin 36. from I can tell , 36 ends up at IBT OUT ( pad q16) , which I was told to make sure there was no jumper there. There was and I disconnected it. So can I just go from processor to q16 - which is connected to pin 36 ?
Steve
Yes, connect the processor wire to IGBT OUT. Check that has continuity with pin 36 first.Madkaw wrote:James,
Sorry if I'm confusing things here, but I don't want the OP to get led astray.
James. what you are saying doesn't seem to correlate to the schematic to me.
As I see it, "IGBTout" does not connect to pin 36. Pin 36 connects to pad "IGN" and a jumper is needed between "IGBTout" and "IGN" to use Q16 as a spark coil driver via pin 36. That jumper, the one from "IGBTout" and "IGN" is the one I think should be removed, if it is there. The processor pin for IAC 2a should be connected to the "IGN" pad and Q16 will be out of the IAC/pin 36 circuit for sure.
