TS 3.0.50.17 freezes on startup.
Reverant
Post by Reverant »
Updated from 30.0.26 on my desktop and 3.0.28 on my laptop, both running Linux.
I get the splash screen but it won't load any further on both machines.
TunerStudioAppDebug.txt:
Code: Select all
Starting on Host
TunerStudio 3.0.50.17 started on Sun Nov 19 09:57:59 EET 2017
JRE 1.8.0_111, Linux 3.xxxxxxx-desktop, amd64
java.library.path=lib/alternateLinuxDrivers/x86_64-linux:lib
TunerStudioMS.jar
Look:Metal, ClassName:'javax.swing.plaf.metal.MetalLookAndFeel'
Look:Nimbus, ClassName:'javax.swing.plaf.nimbus.NimbusLookAndFeel'
Look:CDE/Motif, ClassName:'com.sun.java.swing.plaf.motif.MotifLookAndFeel'
Look:GTK+, ClassName:'com.sun.java.swing.plaf.gtk.GTKLookAndFeel'
Look:Night Shade, ClassName:'de.muntjak.tinylookandfeel.TinyLookAndFeel'
Setting Look & Feel to:de.muntjak.tinylookandfeel.TinyLookAndFeel
TinyLaF v1.4.0
Theme: jar:file:/opt/TunerStudioMS/TunerStudioMS.jar!/Default.theme
ScrollBar.width
11/19/17 9:58:00 AM :Debug: no update:defaultFont
Nov 19, 2017 9:58:00 AM TunerStudio main
SEVERE: null
java.lang.reflect.InvocationTargetException
        at java.awt.EventQueue.invokeAndWait(EventQueue.java:1321)
        at java.awt.EventQueue.invokeAndWait(EventQueue.java:1296)
        at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1348)
        at TunerStudio.main(Unknown Source)
Caused by: java.lang.NoClassDefFoundError: javafx/concurrent/Task
        at ai.dp.<init>(Unknown Source)
        at b.run(Unknown Source)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:301)
        at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
        at java.awt.EventQueue.access$500(EventQueue.java:97)
        at java.awt.EventQueue$3.run(EventQueue.java:709)
        at java.awt.EventQueue$3.run(EventQueue.java:703)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Caused by: java.lang.ClassNotFoundException: javafx.concurrent.Task
        at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
        ... 16 more
The man behind MS Labs
Re: TS 3.0.50.17 freezes on startup.
Post by LT401Vette »
It looks like your JRE does not have JavaFX libraries. It is a 1.8 JRE so it should.. What JRE are you using? Open JDK?
The .17 beta has one of the libraries compiled to 1.8 dues to some file dialog references. They have since been removed, so the next beta doesn't require them. We will be needing to transition to a 1.8 JRE at some point, sort of waiting for all the linux distros to get up to speed.
Reverant
Post by Reverant »
Open JDK 1.7 and 1.8.
It doesn't look like my distribution has JavaFX packages, so I may have to resort to getting them from Oracle.
piledriver
Post by piledriver »
Same boat here, using win10 and despising it. (Although not as much as XP>win 7)
Funny, all the Linux distros I run have been using OpenJVM 8 for a very long time, yet we are just seeing an issue now.
(OpenJVM is the reference JAVA implementation since 1.7 FWIW, Oracles releases are OpenJVM based.)
Reverant
Post by Reverant »
In my case, I did install the OpenJFX package and that solved my issue.
piledriver wrote:Same boat here, using win10 and despising it. (Although not as much as XP>win 7)
Yep, that .17 build had a reference to a JavaFX library as we have been preparing to require a 1.8 JRE. It seemed most linux distos now have 1.8 and windows and OS X use the JRE bundled with it which is 1.8.
However, come to find out Open Java which is common in Linux distros did not include the JavaFX libraries for some reason where oracle started including them in the Core JRE.
At any rate, I have pulled the references out for next release so JavaFX won't kill it.. with the next release.
piledriver
Simply installed OpenJFX.
Its just a matter of knowing you need it.
piledriver wrote:Simply installed OpenJFX.
Yep.. I thought it would be there, but learned it isn't. We are leaving it out future betas until we come with something.
piledriver
It appears to be available but is not part of anybodies std JVM load.
Most distros manage dependencies great but installing from a tarball bypasses that.
Typically one would either list deps or include the needed pkg in the tarball.
It would be pretty easy to write an installer or first run script to check and report issues.
Same problem here, it gets a severe null on attempted startup and hangs at the splash screen. Oddly, it was working ok yesterday and I've not updated since then??
3.0.50.23 is out there, it should no longer have the JavaFX dependency
piledriver
LT401Vette wrote:3.0.50.23 is out there, it should no longer have the JavaFX dependency
Checked for update (on Linux) and it still reports 3.0.50.17 is the latest version.
Simply installing openjfx resolves the lockup issue tho.
(apt install openjfx, or use yum or urpmi as applicable)
Post by racingmini_mtl »
And on Windows.
piledriver
On Windows you may have a different issue, as JavaFX is part of the std Oracle Java JVM.
JavaFX is part of Oracles Java SE since V7, which is sorta confusing since OpenJVM IS reference Java since v7, and OpenJFX doesn't appear to install with OpenJVM by default on any Linux distro I have tried.
Perhaps the Linux distros are all unintentionally skipping it.
(it seems available for install)
piledriver wrote:On Windows you may have a different issue, as JavaFX is part of the std Oracle Java JVM.
What I meant is that the check for the update also shows 3.0.50.17 to be the latest version. I don't have issues with the current TS version under Windows.
It looks like I only had it up for the Dev Edition Beta.
