MLV HD updated now will no open RPI3
Gavin Lodewick
Post by Gavin Lodewick »
Hi I have updated MLV/HD and now it will not open, I have downloaded from EFI downloads aswell tar file for RPI3, and it still will not open. please help. :?
Gavin
Re: MLV HD updated now will no open RPI3
Post by LT401Vette »
update to a 1.8 JRE or install the JavaFX libraries if you are using Open Java
Gavin Lodewick
Hi Phil, new to rpi3 will search for
LT401Vette wrote:update to a 1.8 JRE or install the JavaFX libraries if you are using Open Java
and update.
Gavin
Gavin Lodewick
Hi Phil
still struggling with this, I have installed the latest 1.8 JRE 8u151 java. I struggling with JavaFX libraries.
I see the latest TunerStudio Ultra works on the RPI now, is this the same problem with MLV HD.
Please Help, so I can start Tunning. :idea:
Gavin
DaveEFI
Post by DaveEFI »
When I've had this problem, trying installing a freshly downloaded version of TS or MLV from the official site That seems to sort out any Java funny. Even when it updates after doing this. You don't need to uninstall the old, and all your own files are kept.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
DaveEFI wrote:When I've had this problem, trying installing a freshly downloaded version of TS or MLV from the official site That seems to sort out any Java funny. Even when it updates after doing this. You don't need to uninstall the old, and all your own files are kept.
The only way that will fix it is if an auto update went bad, which is pretty hard these days.
Otherwise you are just deleting files then putting the same ones back and wasting your time.
Gavin Lodewick
Hi Phil
I still canot get MLV/HD to open. Please can you help me.
It use to open before, I not shore which update killed it.
Gavin
Gavin Lodewick wrote:Hi Phil
Gavin
Try installing openJFX
http://openjdk.java.net/projects/openjfx/
Gavin Lodewick
Thanks Phil
I will try to understand all this new Confusion :? .
Please if I do not come right will your team assist me.
Thanks Gavin
Of course, just email.
There was a release of TS a while back that had a JavaFX dependency in the shared core. It was our belief that JavaFX was part of the 1.8 JRE. It turned out that wasn't true, with OpenJDK as used on most linux PC's JavaFX has to be installed separately.
I believe the current version of MLV is using this shared library as well. The next release will have it removed.
Gavin Lodewick
LT401Vette wrote:Of course, just email.
Thanks Phil
I will wait for the next release. where will I find the next release.
Gavin
There should be a new release of MLV in the next week or two.
Gavin Lodewick
LT401Vette wrote:There should be a new release of MLV in the next week or two.
Will the New release MLV/HD work with RPI3.
Gavin
I am assuming so. It has the JavaFX dependencies removed.
Gavin Lodewick
LT401Vette wrote:I am assuming so. It has the JavaFX dependencies removed.
Hi Phil
I failed a gain, I have 2 sd cards 1 with stretch lite imige & 2 with Waveshare 10.1 inch HDMI LCD imige, neither will open MLV/HD with the latest F/W :?
am I the only one with this problem.
Gavin
