While I'm tuning a car, I noticed that this happen often. On a ms3pro and on an ms2.
If I do changes offline, as soon as I connect I loose I my changes without being notified that the ecu and the tunerstudio settings are different.
This is very annoying.
Tuner studio version is 3.0.28.
I'll try to upgrade to 3.0.50.17
Offline changes lost
Re: Offline changes lost
Make sure you don't have "Difference reporting" or "Automatically load and save Current Tune" turned off.
Options --> Preferences --> Perform Difference Report on Connect
Options --> Preferences --> Automatically load and save Current Tune
Both need to be checked to always be prompted on a difference.
Thanks! Perform Difference Report on Connect was unchecked for an unknown reason!
