4L80E setup and log files
hi guys (and girl?),
I bought a Microsquirt in januari of 2015 and finally got around to installing it together with my 4L80E transmission in my car. This is my project page:
http://www.facebook.com/77suburban
I made a succesfull test drive yesterday. I think I got it all worked out, but Id really appreciate it if you guys could look into my setup file and tell me what I see in my log file. This is my first Megasquirt install and In have no experience with 4L80E transmissions.
setup file: log file: my setup:
Microsquirt V3 for transmission control
1977 GMC C15 suburban with Big Block V8 7.4L
HEI ignition
bi-fuel: carburator for gasoline and IMPCO300 mixer for propane
for a tach signal I got help from a facebook group and now use this zener diode solution to connect to my TACH connection (coil negative) on my HEI ignition: the signal seems clear and first test drive was OK.
The 1-2 shift is pretty hard, while other shifts aren't as hard.
Could you please help me by looking at my setup and log files and check if I am OK? would really appreciate that
HEI ignition
- Attachments
- 2017-11-11_17.09.41.msq
- my msq setup file
- (25.43 KiB) Downloaded 80 times
my project page, BBC 454 with LPG vapour injection:
my BBC 454 LPG vapour injection tuning story
my Facebook projectpage:
My 1977 GMC C15 Suburban "Storm"
Re: 4L80E setup and log files
and I allmost forgot. I am running MAP sensor for LOAD INPUT, since I dont have a TPS sensor yet.
and also noticed when I floored it yesterday, it didnt downshift
Did you select MAP sensor for load in the settings? I am in a place where I can view the log, but not your .msq file.
For the 1-2 gear shift, about all you can do is reduce line pressure first gear (if it is harsh on the 1-2 shift). Is it harsh like "normal" shift kit harsh? Or harsh like "its going to break something?"
hi Wes, cool to see you answering my topic over here too...very cool!wes kiser wrote:Did you select MAP sensor for load in the settings? I am in a place where I can view the log, but not your .msq file.
Yes I set the MAP for load indication in the BASIC SETTINGS.
There is only on main linepressure table/graph, but I have these curves for shifting (defaults): and the shift is FIRM...not like harse stuff is gonna brake, but fels like a good kick! compared to the smooth shift for 2-3 during normal acceleration.
any thoughts on the downshift?
Get a log of a point you expect a downshift to happen. Are you happy with shift points?
ok, Ill see if I can get that figured out.wes kiser wrote:Get a log of a point you expect a downshift to happen. Are you happy with shift points?
I have only made a short test run...maybe 2-3 miles and not above 50mph...so never got to 4th of lockup
I found out why It shifts so hard.
I am using MAP for load indication, because I don't have a TPS yet. It is showing 80% load when it's idleing. So guess that's the problem.
I have no idea where I should adjust this. All tips are welcome
Where/How did you connect the MAP-sensor on the engine?
Put a regular vacuum gauge on the hose and see if the reading corresponds to the digital MAP-gauge.
Hi Herman, the connection is right at the base of the plenum, so full manifold.
I need to see if I can find a gauge and hook it up.
the strange thing is my reading are going down, when they should be going up. or shoudlnt they?
engine OFF, Key ON: gauge maxed out at 100 kPa
idle: 75-80kPa
part throttle, cruise: 55-60 kPa
idle: 75-80kPa
looks like you have a bit of a cam in it, if you do that is a normal reading, tps works much better for trans control. your shift points are way too low. i have found you can just about double the default curvs and will bee closer
My engine is bone stock. So the readings can't be right.ashford wrote:looks like you have a bit of a cam in it, if you do that is a normal reading, tps works much better for trans control. your shift points are way too low. i have found you can just about double the default curvs and will bee closer
I am using this ebay 3bar map sensor
https://m.ebay.com/itm/New-GM-STYLE-MAP ... SwuhhXUS8B
Ill see if I can borrow a vacuum gauge and check the readings and volts
well, steep learning curce these last few days.
checked my MAP sensor with a vacuum gauge:
https://youtu.be/LCjEqlvDzl8
found out that my engine had 2 exhaust valves set to tight after the rebuild causing a erratic vacuum reading:
https://youtu.be/GK4xu28iUEg
I fixed that by going over all the vales and finaly found exhaust 6 and 8 were tight
video of running engine without valve covers
https://www.youtube.com/watch?v=CZbIRxe-s-A
video of steady vacuum reading after loosening exhaust #6 and #8
https://youtu.be/Xxgfbr2Inqw
what I learned is that not just intake vales can cause bad vacuum readings, but also the exhaust valves.
I was helped by Dave Buck Shaw in this troubleshooting of my engine through messenger, pretty awesome.
then I still had the problem that the 50kPa at idle was causing a 50% lead reading, so the transmission would shift late and hard.
Jesse Brown, friend on Facebook, then explained to me that there is no such thing as 0% load when using MAP for load indication. He then explained to me how the MAP reading is a reference to use and that the TCU will shift on load at a certain vehicle speed and that I had to adjust my shift curves myself.
I did just this and now I am getting much better shifts and even drove it home.
I'll upload my MSQ file later today, hope it helps somebody else too
this is my latest MSQ file.
My engine idles at about 50-55kPa. So my LOAD is at 50-55% at idle and I worked from there in the various configurations.
QUESTION:
I am looking for a stock line pressure-load table for a stock 4L80E. Can somebody point me to this?
QUESTION:
I bought a oil pressure test gauge, because I wanted to do a line pressure test. Which is always good to perform after you rebuild your transmission. I included a photo that has reference values. Values can be different based on special modifications made to the transmission.
my readings turned out OK:
Line pressure test cold:
Idle P/N 130 psi
Reverse idle 200 psi - WOT ~300 psi
D idle 140 psi - WOT ~200 psi
so cold readings are fine. Now I need to take some readings with a well warmed up engine, to be 100% sure
Idle P/N 130 psi
I tested tonight to see what the influence is of adjusting the linepressure table, versus the measured lineressure with a gauge.
I tried several settings for idle 5, 8, 10, 15 and even 50% linepressure. But the measured line pressure never goes below about a 100 psi in idle and D....it will rise when I raise the linepressure percentage in the table.
So how is this handled? is there Always a MIN from where the solenoid of the linepressure can only go up?
I have to mention that my 4L80E had the Transgo shift kit installed
http://www.transgo.com/products.php?prd ... ntview=Yes
I had a long drive this weekend. total of 269 km. I notice that the 1-2 AND the 3-4 have the THUD at light throttle. Even my passengers asked me about it "is that normal?"
2-3 shift on the other hand is smooth as butter, no slip, just smooth soft engagement at light throttle.
In my case light throttle is between 55 and 65 kPa, which in the LOAD table corresponds to 0-20% load
any thoughts on where to go with my tune to make these light throttle shift for 1-2 and 3-4 smoother?
I did some more testing this weekend.
first tested line pressure agin witrh a dry pressure gauge. And the needle jumped all over the place:
https://youtu.be/lmOwWPBd604
then borrowed an oil filled gauge and everything looked fine:
https://www.youtube.com/watch?v=6Av3OxmR9Sc
I then put the Microsquirt in TESTMODE and tested the line pressure at different settings. I noticed that any setting below about 15% would make the trans start to shake. And also that line pressure will not drop below 100 psi, even if I set it to 2 or 3%. It does rise above to about 150psi when I set it at 50%. So solenoid seems to be working fine.
So still dont understand why my 1-2 and 3-4 like a THUD and 2-3 is smooth.
I would really appreciate it if somebody would read up and give me feedback on the information I shared. I am new to this stuff and was really hoping to find some support over here.
Don't know much about automtaic transmissions but dit you try the manual ?
http://www.msextra.com/product-range/ex ... n-control/
You don't have to read the whole manual just the parts you need.
so shift 1>2 not so good
shift 2>3 good
shift 3>4 not so good
If you are looking at youre datalogs and compare the "good" an "not so good" shiftings.
Isn't there something that looks awkward ?
shift 2>3 good
hi thanks LAV1000 I read the manual several times, because I did my own install...thanks...LAV1000 wrote:Don't know much about automtaic transmissions but dit you try the manual ?
shift 2>3 good
I am new to this, so dont know what things to look at in the log files to compare...any tips?
