I'm not sure if you know this but you cannot run sequential injection with only an EDIS module as your tach input. You also need to add a cam signal. Otherwise you can only run semi-sequential injection since the ECU has no information on the phase of the engine with the EDIS signal.garrycol wrote:... Anyone got a map for a Thor running on EDIS8, sequential injection but batch ignition? ...
By the way, even you were to not use the EDIS module and connect the 36-1 wheel directly to the MS3 you would still need a cam signal to run sequential injection. A crank-only signal is not sufficient for sequential injection (or ignition).
