That’s between cable vr+ and cable vr- I meant.
Just to confirm my suspicion towards the faulty afr readings, I’ve attached a image ive found on line.
Is this the way the afr curve is supposed to look?
flat afr and rpm drop in log file
Re: flat afr and rpm drop in log file
- Attachments
- Screenshot of a working afr curve?
- A2430B48-2E03-4DD5-AD7C-1F5747CC730A.png (115.04 KiB) Viewed 308 times
Difficult to analyze a picture, but that looks ok.
