TPS values
Click here to enter
Contact a Forum Administrator
Griso
TPS values
Post by Griso »
Hi All
Trying to configure the ITB lode settings.on Moto Guzzi 1200 8v
Can’t get the TPS value across the RPM range, from the manufacturers.
If anyone our there installed a Microsquirt on a Moto Guzzi EFI
and have these values for me, It will be greatly appreciated.
Griso
Dennis_Zx7r
Re: TPS values
Post by Dennis_Zx7r »
This depends highly on your setup. If you have a large datalog and are confident you've correctly calibrated you TPS and adjusted your idle, you can send it to me via private message if you have trouble extracting the curve. I suggest watching https://www.youtube.com/watch?v=_GDZxUVTplk and trying it yourself first, though.
My project: Link
Griso
Re: TPS values
Post by Griso »
Thanks Dennis
The video was very helpfull, my only question is, can i do the data logging by just revving up the engine.
Or do i have to do it on a dyno
Griso
Dennis_Zx7r
Re: TPS values
I doubt this will work without load on the engine. Also, note that you're not looking for 90kpa, but for 90%baro.
My project: Link
Griso
Re: TPS values
Post by Griso »
Thanks Dennis
Griso
Re: TPS values
Post by Griso »
Hi Dennis
I apologise for taking so long to get back to you, I needed to fabricate a mount to hold the laptop on the motorbike so i can do a data log
I’m not getting 90% on the Histogram / Table Generator. Data Loge Please find data loge attached
Dataloge7.msl
(570.18 KiB) Downloaded 23 times
Dennis_Zx7r
Re: TPS values
Calibrate your TPS and verify it's working correctly afterwards. According to the log, it currently does not.
My project: Link
Griso
Re: TPS values
Post by Griso »
My problem is i can’t calibrate because I’m not getting the same table in Histogram as in the vedeo.
I have the X Axis = RPM Y = TPS and Z = MAP. What do i need enter in Z Axis Delta.
Are you abel to get a table showing 90’s from my log?
Dennis_Zx7r
Re: TPS values
Your TPS is not calibrated correctly or malfunctioning. You have to fix this first!
My project: Link
