Feature request EGO Correction add fuel only
I was a PRI in the last few days at the DIYAutotune/AMPEFI boot and a customer requested this and I liked the idea.
We want to be able to specify ego correction to only add fuel and not remove it. Actually, the authority number is a +/- % so if you authorize 10%, it can add up to 10% more fuel but can also remove 10% fuel too.
It would be great to be able to specify a different maximum correction authority on both add and removing fuel. Holley does that. So you can tell your ego correction to only have the right to add fuel at idle and not remove fuel.
Maybe a simple solution, for now, would be to add another menu to the ego options to specify how the authority percentage (or table) work with 3 options. It can add both and remove fuel, only add fuel, only remove fuel.
Let me know what you think.
Re: Feature request EGO Correction add fuel only
I think it's a good idea, but I think that the simplest way would have two input values : "Min correction %" and "Max correction %". This way you have your desired feature with only two input values.
Sam
Sam
+1 for this - I think it's a great idea.
Sydney, Australia
1971 Holden Monaro HQ
yes, best way to do it is with 2 tables. min table and max table so you can specify if you allow to remove and add fuel.
This would indeed be a nice improvement and definitely just separate correction add and correction reduce with 2 tables instead of the single table we now have.
Support the developers!
great idea, ive seen it in way less capable ecu's. Fast XFI and Hydra both have it.
BootlegTuned
i used this type ego correction 8 years ago. maybe this help.
look at O2 compensation limit.
- Attachments
- used this eco correction in an old standalone system.
- egocor.jpg (188.44 KiB) Viewed 520 times
Nice Commander950 screen shot, I only stopped using that ECU 2 years ago, although I had written my own tuning software to work with it in C++ and then again later in Java. I used to rely on the EGO correction a lot more then - with the MS3, I'm much happier using auto tune and all the modifiers to make the maps right and then using AFR shutdown when things go wrong instead of counting on EGO correction because the ECU didn't have the ability to model all the variables.
Camaro, Mark IV aluminum big block Chevy, 8.8l, Procharger F1-R @ 12psi, MS3Pro
Has there been any consideration on this?
BootlegTuned
