CAN LOTUS BROADCAST
Re: CAN LOTUS BROADCAST
Hi James, sorry for retard, yesterday i have tested the car.
Result:
-CLT Ok
-RPM Ok
-KMH Not work (why? in the first test has good)
-Fuel level OK
-SHIFT LIGHT OK
- OIL WARNING LAMP OK
- MIL/CHECK LAMP tested status when engine not running and it's OK
The msq: Bye, Luca
Result:
-CLT Ok
-RPM Ok
-Fuel level OK
-SHIFT LIGHT OK
The msq: Bye, Luca
Luca from www.megasquirt.it
Something strange with the speed calc, the broadcast testing results don't match up with the reverse engineered spec for the speed.
Test code sent.
Test code sent.
I James,
I see your txt. I think there is a error in the conversion.
My idea is:
kph = (unsigned int) ((outpc.vss1 * 530538ul) / 10000ul);
From outpc.vss1 = 100, we get kph = 5305
vssout=(unsigned int) ((kph*912)/1000) //***** 100*912/1000 = 91= 5b
data[0] = vssout
data[1] = NOT USED
My idea is:
data[0] = vssout
data[1] = NOT USED
Did you test the latest code I sent? It was similar to the first version with the scaling factor set to 92% of the original.
kph = (unsigned int) ((outpc.vss1 * 3312ul) / 10000ul);
From outpc.vss1 = 100, we get kph = 33
(36 * 92% = 33)
data[0] = 0
data[1] = 33
The error is in data1... data1 NOT USED
(36 * 92% = 33)
data[0] = 0
data[1] = 33
That's not what code I sent looks like though?
For 10.0 ms-1 that gives data[0]=20 (20mph ?)
One of the data sources said that the speed was in mph.
Be aware that the test code I sent is clobbering "Sensors 5" with the raw value of "kph"
Code: Select all
kph = (unsigned int) ((outpc.vss1 * 530538ul) / 10000ul); /* Tweaked scaling based on 'flycat' feedback */
data[0] = (kph >> 8) & 0xff;
Hi James, sorry for retard, i have tested the last code, now all fuction are active , kmh value isn't correct , but i have "calibrated" with a gps...with 1.35m of wheel diameter the value of instrument is correct
Now we need only a correct scaling factor
Bye, Luca
Bye, Luca
