MS3 knock sensor wiring question.
GeorgePatches
Post by GeorgePatches »
I'm setting up a 305 TBI with a MS3 and I'm planning to use ON/OFF knock control with a GM knock module as referenced in the instructions here.
http://www.msextra.com/doc/pdf/html/MS3 ... .4-39.html
I'm not understanding if I need to build a protective circuit as referenced on the next page?
http://www.msextra.com/doc/pdf/html/MS3 ... .4-40.html
Or if I need some other kind of protective circuit for use with the GM knock module or don't need a protective circuit at all?
KAT PWR
Re: MS3 knock sensor wiring question.
Post by KAT PWR »
I haven't done an analog setup but, I would say after reading you need the protective circuit. internal mode is only if you get the knock and add-on board.
With MS3X, you should be able to run the signal into a switched input on the MS3X and have it work fine.
GeorgePatches
I actually found the answer on the megamanual website for the MS2.
http://www.megamanual.com/ms2/knock.htm
The signal output is going to come in at 8-10 volts from the GM module, so I need to build that circuit with a zener diode to bring it into the 0-5 volt spec for JS4 or JS5.
prof315
Post by prof315 »
GeorgePatches wrote:I actually found the answer on the megamanual website for the MS2.
DO NOT USE THE MEGAMANUAL! It's obsolete and some of the info is actually wrong . Use the manuals linked at the top of the page.
Support the developers!
The MS3X digital inputs already have the clamping circuit installed.
GeorgePatches
Matt Cramer wrote:The MS3X digital inputs already have the clamping circuit installed.
I have a MS3 Base though. Is there a CPU input other than JS4 and JS5 I can use to accomplish this without a protective circuit?
Well the manual at the top of the page it's not clear if I need a protective circuit, nor does it give me any details on how to configure the MS3 with the GM knock module (going high versus going low). This at least clarifies what I had questions about.
prof315
Post by prof315 »
The schematic on page 40 ( linked in your original post) is what you need. I 'm not sure what your confusion was.
66FairlaneGTer
Post by 66FairlaneGTer »
Did you ever complete wiring to your SPR3, and if so, did it work as you hoped it would?
1966 Ford Fairlane GTA, 428 EFI (Working on it); 1986 K5 Blazer, MS3 - 383 Stroker ...Jesus, Wife and Kids MUCH more important!
