Bloody filter!!!
Bloody filter!!!
Hi guys
I can't Ve analyse because it keeps saying my log was 99 percent filtered!! Due to min clt values.
I have tried setting to very low levels to avoid filter, and have filter turned off
Really frustrating because I can't tune!!
It's a 911 Porsche 2.7 with ms2
Suggestions?
Suggestions?
Re: Bloody filter!!!
I guess that you have a fixed temperature because there is no or you didnt connect the temp sensor.
Check your temperature value, and adjust filter to it.
Sorry guys
Heres a log
Hope it helps as its preventing me from using the tuning functions of megalog
I know its not running as well a sit could be but any advice is much appreciated
Cheers
Dan
Heres a log
Cheers
Dan
- Attachments
- 2017-12-11_13.55.31.msl
- datalog 911
- (1.48 MiB) Downloaded 39 times
I see a couple of odd things in that log.
I'm thinking we still need to see your tune file (msq)!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
here it is
- Attachments
- 2017-12-22_22.06.11.msq
- (118.98 KiB) Downloaded 35 times
No TPS or IAT sensor?
Hi Ken
I do have tps but whats the other one?
As you can tell I'm new at this!!
IAT or MAT refer to Intake Air Temperature or Manifold Air Temperature; they're the same. Basically the temperature of the air before it enters the engine.
This seems to be an issue with what you set for your filter criteria. I can use VEA just fine using your datalog and MSQ.danbeck wrote:I can't Ve analyse because it keeps saying my log was 99 percent filtered!! Due to min clt values.
My project: Link
Thanks for the feedback guys and Merry Christmas!!
I'm so green at all of this. I really underestimated how challenging tuning is...
If I could get the megalog to stop telling me my log was filtered Id have a shot
What am I doing wrong??
Ive attached a couple of photos
022 by Dan Pfitzner, on Flickr
023 by Dan Pfitzner, on Flickr
024 by Dan Pfitzner, on Flickr
What coolant temperature are you seeing? From the message it must be wildly inaccurate or you are in Siberia?
If your basic sensors aren't reporting accurate numbers you MUST fix that before trying autotune.
I think this might be more of an issue with the negative number he put in.
His CLT in the log seems reasonable and it worked just fine on my version of MegaLogviewer and MinCLT 60.
Edit: I also just tested this with the -22 he entered in the screenshot, and this still works fine on my computer. As I already said I'm using MLV though.
His CLT varies between 150 and 170°F, so this seems to be in order.
My project: Link
It didn't matter if I posted a low positive number or put in -22 (just to get it away from filtering)
Is there anything else that could be a problem?
Maybe Ill try again? There must be a reason this is being filtered
Thanks for your feedback
I worked it out!!!
Had to go into another menu
Thankyou for all of you help. See you next crisis
