Export Loaded Log As
W126
Post by W126 »
I've exported a log but don't see any difference compared to the original.
What does Export do, is it just copy ?
kjones6039
Re: Export Loaded Log As
Post by kjones6039 »
If I'm not mistaken, Export is equivalent to Save As, which simply allows you to provide your own file name.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
W126
Post by W126 »
so it's the same as copying the file ?
As far as I'm aware, if you trimmed the log, the Export will save that shorter trimmed version.
kjones6039
W126 wrote:so it's the same as copying the file ?
For the most part.
jsmcortina wrote:As far as I'm aware, if you trimmed the log, the Export will save that shorter trimmed version.
And that also.
Post by LT401Vette »
As James said.. If you have edited the content of what is loaded, it will save what is now loaded.
So if you Trim after cursor, before cursor, etc... Those parts are gone and will not be saved.
Also your calculated fields will be saved to the new file..
W126
Post by W126 »
thank you Phil
