So, I have a strange issue, sometimes the 2 steps works great, ie, I can rev the engine to 7k, step on clutch, rev drops while I still WOT.
Other times, the 2 steps rev limit seems to activate without the clutch switch input while I am still WOT, the log reflect this.
Looking for ideas. Thanks.
2 step sometimes work, some doesn't.
- Attachments
- 2017-12-27_15.52.05.msq
- (119.95 KiB) Downloaded 20 times
- 2stepworking.msl
- (89.74 KiB) Downloaded 20 times
- 2step not working.msl
- (72.63 KiB) Downloaded 20 times
1985 Dodge Omni GLH Turbo MicroSquirted 367whp http://www.msextra.com/forums/viewtopic ... 04&t=67324
Re: 2 step sometimes work, some doesn't.
Maybe use a pull up/down resistor set up on the clutch input ?
This way the input doesn't float when not active.
The log definitely shows the clutch switch input triggering on the "not working" log - see ADC7 drop at about the same time it applies the 2 step.
