Is MSDroid Still Active?
Use and development of MSDroid tuning software on Android
Postby VcrMiata » Sun Apr 09, 2017 5:42 pm
Hey Trev,
It's been 3 or 4 months since you've engaged on the changes you were implementing for MSDroid.
Have you finished your house?
Are you still working on MSDroid?
MS3 Basic + FW1.5 + CAN device is broken and I'm really missing using it for quick tune mods.
If you need more information, please let me know.
Tony
VcrMiata
Re: Is MSDroid Still Active?
Postby Trev16v » Thu Apr 13, 2017 4:39 am
Hi Tony,
I'm still very active on it, but unfortunately work and life pressures are getting in the way again. I'll do my best to try to catch up with support as soon as I can.
Sorry for this.
Trev
Golf MK2 G60 Syncro with 16VG60 on MSNS-E
MSDroid :: MegaSquirt tuning on Android
Trev16v
Postby VcrMiata » Sat Dec 30, 2017 11:41 pm
Hi Trevor,
It's now been a full year since the last functional update to MSDroid.
And, I have not been able to use MSDroid for tuning for almost the full year since it is not compatible with MS3 FW 1.5 and CAN AFR/EGO.
I can only use MSDroid for monitoring at which point I just prefer using ShadowDash instead.
Whenever I connect to the ECU a difference is detected and I need to select "Update Project Settings" to continue.
If I make a change and update the ECU, my CAN based O2 sensor stops working and I need to use TunerStudio to restore functionality.
From reading other threads it appears this is likely due to MS now using parameterized lists in its configuration.
Is there any plan to have MSDroid updated to support parameterized lists?
If so, is there any timeline?
I hate having to carry my laptop around for minor tuning and this is the main reason I purchased MSDroid in the first place.
For example (this is not exhaustive):
1) General Settings page:
Voltage Input Port shows $PIN_ADCS instead of Mainboard
2nd MAP Port shows $PIN_ADCS_OFF instead of off
2) Shift Light page:
Shift Light Output shows $PIN_DIGOUT_CANOUT_OFF instead of off
3) Torque Convertor Lockup page:
Output Pin shows $PIN_DIGOUT_CANOUT_OFF instead of off
4) Alternator Control
Current Monitor Input shows $PIN_DIGIN_OFF instead of off
5)AFR/EGO Control
AFR /EGO Sensor Mapping - Uses Sensor shows $EGOMAP instead of "EGO1"
6) CAN Receiving page:
Local variable / channel shows $CAN_RCV_VARS instead of off
7) Check Engine Light page:
Light output shows $PIN_DIG_OUT_CANOUT_OFF instead of off
8) Long Term Trim Settings page:
LED output shows $PIN_DIGOUT_CANOUT_OFF instead of off
9) SD Card Datalogging
LED Indicator shows $PIN_DIGOUT_CANOUT_OFF instead of off
VcrMiata
Postby Razkal » Tue Jan 02, 2018 5:14 pm
I'm also very interested in this, recently got my ms3 tuned and running. Even more recent is the lenovo tab I bought and the apps I downloaded in hopes of running and Android dash.
Haven't been able to find ANY recent info for any of the apps (MSdroid, ShadowDash, RealDash), my rs232>micro USB and an rs232>bluetooth should be here soon.
I'm really hoping I didn't invest in a fossilized concept.
Aks.
Razkal
Postby Trev16v » Sat Jan 06, 2018 8:30 am
Still very active; I'm actually spending several hours a day on average on MSDroid in between work and other commitments. However, I'm still struggling to keep up with a lot of support requests and fixes at the moment. I will get there eventually. I appreciate that me coming out with lots of words yet not having anything visible to show for it is hardly convincing, but I feel it's better than saying nothing at all.
Trev16v
Postby jsmcortina » Sat Jan 06, 2018 9:32 am
Trev16v wrote:Still very active;
It seems that it doesn't support the current release of MS3 firmware though, this needs to be called out before customers buy it. I checked the Google Play download page and it says that there is full support for MS1/2/3.
Postby Trev16v » Thu Jan 11, 2018 3:40 pm
You're right. It's bad and I take it on board. My problem is not so much lack of work on MSDroid, but more so poorly prioritising essential support and fixes against working away on shiny new stuff.
As mentioned in the other thread, I have now done the .ini preprocessor support to address the main issue reported above by VcrMiata, so I shall provide this fix (plus further MS3 1.5.1 fixes that I work on) in a beta release via Google Play at the weekend.
Trev16v
Postby VcrMiata » Fri Jan 12, 2018 10:12 pm
Cool, thanks Trevor!
Looking forward to the beta this weekend and being able to tune again.
Tony
VcrMiata
Postby Trev16v » Mon Jan 15, 2018 4:20 pm
I have now pushed beta release 2.6b1 to Play, which has two fixes: (1) fix for MS3 1.5.1 support as discussed above, and (2) a fix for the new table editor crashing on Android 4.x.
You'll need to be registered to receive releases on the beta channel. If you're not already registered, the details are in a thread in this section. But let me know if you get stuck.
Trev16v
Postby VcrMiata » Mon Jan 15, 2018 8:43 pm
Hi Trevor,
Thanks for posting the 2.6b1 beta.
What is the expected status of this beta?
I'm finding quite a few issues.
1) Opening almost all screens with tables causes the application to crash.
for example, the following non-exhaustive list all cause the application to immediately crash:
Basic/Load Settings
Rev Limiter
Alternator Control
Barometric Correction
Map Sample Settings
MAT Air Density Table
MAT/CLT Correction
Fuel Settings
Injector Dead-Time/PWM
Injector Small Pulsewidths
Ignition Settings
Dwell Battery Correction
Cold Advance
MAT Based Timing Retard
---> and many, many more
2) Parameterised lists not using default overrides.
For example:
Note: my TunerStudio .msq file shows mapport configured as "Mainboard"
<constant name="egoport1">"CAN EGO"</constant>
Page: General Settings->mapport (Voltage Input Port) is showing "JS5 (ADC6)" instead of "Mainboard".
mapport has the following definitions:
mapport = bits, U08, 242, [0:5], $PIN_ADCS, 0="Mainboard"
this should override the $PIN_ADCS list which is defined as:
#define PIN_ADCS1 = "JS5 (ADC6)", "JS4 (ADC7)", "EXT_MAP (ADC11)", "EGO2 (ADC12)", "Spare ADC (ADC13)", "MAP", "INVALID", "CAN ADC01", "CAN ADC02", "CAN ADC03", "CAN ADC04", "CAN ADC05", "CAN ADC06", "CAN ADC07", "CAN ADC08", "CAN ADC09", "CAN ADC10", "CAN ADC11", "CAN ADC12", "CAN ADC13", "CAN ADC14", "CAN ADC15", "CAN ADC16", "CAN ADC17", "CAN ADC18", "CAN ADC19", "CAN ADC20", "CAN ADC21", "CAN ADC22", "CAN ADC23", "CAN ADC24", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "EGO", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID", "INVALID"
#define PIN_ADCS = "INVALID", $PIN_ADCS1
$PIN_ADCS needs to be translated to show "Mainboard", not "JS5 (ADC6)".
Another example:
Note: my Tunerstudio .msq shows egoport1 as "CAN EGO"
<constant name="mapport">"Mainboard"</constant>
Page: Fuel Settings->AFR/EGO Control->egoport1 (EGO 1 Port) is showing "EGO" instead of "CAN EGO"
egoport1 has the following definition:
egoport1 = bits, U08, 40, [0:5], $PIN_ADCS_EGO, 7="CAN EGO", 38="INVALID"
#define PIN_ADCS_EGO = "EGO", $PIN_ADCS1
VcrMiata
Postby Trev16v » Tue Jan 16, 2018 2:32 am
This is not right at all and suggests something wrong with the .apk I built, because it doesn't appear to have incorporated my fixes. This is what happens when you rush out a build just before going to sleep in a hotel room!
Sorry for this - I'll investigate this evening.
Trev16v
Postby Trev16v » Thu Jan 18, 2018 6:11 am
VcrMiata, what is the device and Android version you're using, please? When 2.6b1 has crashed on various tuning pages, could you please ensure that a crash report is submitted to Google if you're given the opportunity? I have a separate issue in that our own separate crash reporting system isn't currently reporting from the beta, so I don't yet have any crash reports from your device. I speculated that you're using Android 4.x on which the table editor was known to crash, but that's fixed in 2.6b1.
The other fix is in progress but I'm still trying to understand the above issue.
Trev16v
Postby Trev16v » Thu Jan 18, 2018 7:09 am
Wait! Ignore that. I was being retarded. I've found the bunch of crash reports from the beta from the curve editor crashing on a Galaxy running Android 7.0 which must be you. Cool.
Trev16v
Postby VcrMiata » Thu Jan 18, 2018 6:13 pm
Hi Trevor,
Yes, it's android 7.0, on a Samsung Tab S2.
Do you need a crash report?
Tony
VcrMiata
Postby Trev16v » Fri Jan 19, 2018 3:38 pm
Hi Tony,
Many thanks, and I have what I needed after all -- I found the crash reports your device had already sent. I've now pushed 2.6b2. It has fixes for the above issues. Work continues.
Regards
Trev
Trev16v
Return to MSDroid
