Hi
After changing MS2extra firmware to the latest, I cannot access the over run fuel cut menu, it just won't open using a win 8.1 tablet. I have put the MSQ on my home PC and it opens up fine. Anyone else found this?
thanks
Currently Lotus 23C replica Audi 1.8T MS 2 v3 Sequential COP and ignition.
Lotus 7 replica 4age 20V blacktop MS2 v3
Re: over run fuel cut menu
This is odd, shouldn't be anything special with that dialog.
Please attach your MSQ file. This helps us get as close to your setup as possible making it easier to reproduce/troubleshoot the reported behavior.
What version of windows is on your home PC?
What version is your TunerStudio tablet vs PC?
Has the tablet been connected to a external monitor? (could the dialog be popping up outside the normal desktop area)
P.S.I just loaded ms2extra-release-3.4.2 firmware with default firmware tune on our bench MS2. The Over-run fuel cut menu came up just fine on my Windows 10 laptop running TunerStudio 3.0.28 (stable) and 3.0.50.40 (beta)
I will see if I can track down a Win8.1 PC that hasn't been upgraded to Win10..
Are you using the Beta TS?
There was an issue in recent betas where it would not display some Curve Graphs, this was fixed in 3.0.50.40 just last week..
If on the beta do a check for updates under the help menu.
Thanks MSQ attached. Win 8.1 on tabletsschutte wrote:This is odd, shouldn't be anything special with that dialog.
Win 10 on PC
Tablet TS version:3.0.28
Firmware freshly downloaded: 3.4.2
I have rebooted the tablet a few times with no difference, the menu features above and below over run still work.
Ironically the issue I am having with my tune is over run fuel cut - but cannot access it
thanks for your help
- Attachments
- 20v CurrentTune.msq
- (119.01 KiB) Downloaded 32 times
I looked at your msq and over run fuel cut is there and opened for me
David
David
Yep........ Worked for me too!turbo conversion wrote:I looked at your msq and over run fuel cut is there and opened for me
David
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Yea, works on my home PC and had to change the fuel cut settings by sending the file to that and then send back to tablet. I suppose the version on my tablet could be, for some reason, corrupt.
