Remote Tuner Available
Post here if you are seeking local tuner assistance
Snuggs_A1
Re: Remote Tuner needed
Post by Snuggs_A1 »
I have a 1995 mustang 5.0 swapped with ms2 system, car does not run as it sits right now and need help from a remote tuner
svo375
Re: Remote Tuner Available
Post by svo375 »
have an 1986 mustang svo with upgraded 2.3 Turbo. need help with tuning. car runs, erratic idle, needs to have setting checked and be fine tuned Have megasquirt 3, tunerstudio 3.1.08 ms
90boost
Post by 90boost »
Im need of some fine tuning. I have a volvo with 2.3 with turbo on e85. Running MS2. Car runs good but is really rich etc. Heres my email kevin.mcneely@sbcglobal.net
Unsure how this works but will wait to hear from ya.
JRussell
Post by JRussell »
I'm in need of some tuning help with foxbody 5.0 motor I'm out into a early bronco. Installed MS2, vehicle will start but runs very rich and misses badly. Remote tuning help would be appreciated or recommendations for the Houston, TX area
Javisupra
Post by Javisupra »
Hello, I need help with my 2jz, when cold it starts perfectly, when hot it takes a lot of work to start, when it starts it takes several minutes to get the RPM right, can you help me?
extremetownie
Post by extremetownie »
I need help with a tune. I can not figure out how to PM you.
Sevindeess
Post by Sevindeess »
Working from home today. If anyone needs anything feel free to PM
robbie97381
Post by robbie97381 »
I'm in need of a little help. I have a all-stock 6.0l ls in a jeep. I built it but tuning isn't my thing I can't seem to figure out the MAT-Base timing retard.
Reds1
Post by Reds1 »
Hello I have a Miata on mega squirt looking for someone to tune it for me. Jesusarnaez@outlook.com
Les_Paul
Post by Les_Paul »
I am struggling with with debugging TPS problem and I need a specialist hand.
I’ve bought miata NC built with eaton compressor and running MS3. It uses stock NC 6pin throttle without idle bypass. Was working well but one day RPM started to stick.
Found that throttle power cables are connected directly to ecu, but TPS signal in logs actually comes from the pedal, TPSADC is always 0. I clearly see the real signal from throttle in Output channel canpwmin1. Throttle reacts few times after power on and I loose control after. So engine goes idling at around 2300 RPM and no throttle control. It is not a throttle body fail and not a wiring problem.
Please write me if you may deal with it remotely.
g.pugachev@gmail.com
Appreciate it!
prof315
Post by prof315 »
Les_Paul wrote: Sat Apr 13, 2024 3:05 am Hi,
Appreciate it!
What is the system using to control the throttle body? MS3 only supports drive by wire via 3rd party stuff like DBWX2.
Support the developers!
