Hey guys,
I wasnt able to find the knock module on DIYautotune. Does anybody know if its still available? Are there any suitable replacements?
Thanks,
Megasquirt Knock Module
Re: Megasquirt Knock Module
I had the same problem a few months ago (it was still listed but out of stock) and could not find a replacement. I do not know if they will be produced again but I do hope so.
anclamotorsports.com claims to have stock. I haven't contacted them.
I saw that. Their website looks sketchy though.dontz125 wrote: ↑Mon Mar 25, 2024 2:17 pm anclamotorsports.com claims to have stock. I haven't contacted them.
Since you're posting in the MS2 section, I assume that's what you have. You should know that the knock module is exclusively for the MS3 so regardless of availability, you cannot use it. With the MS2 you need an external unit.
My mistake. I have an ms3x. Wasnt paying attention.racingmini_mtl wrote: ↑Mon Mar 25, 2024 9:56 pm Since you're posting in the MS2 section, I assume that's what you have. You should know that the knock module is exclusively for the MS3 so regardless of availability, you cannot use it. With the MS2 you need an external unit.
