I have a '92 BMW 525i that I am still trying to set up properly for MS-1 v3 MSnS-W 029Q2. I purchased DIYAutotune PWM Idle circuit kit.
My IAC valve is a Bosch model part num BSH046578 which seems is shared also with the E30 325i's with M20 motor...
Question is, in my service manual the stock ECU pin out says Pin 2 on engine harness is Idle Valve "pulsed ground - close signal" and Pin 29 is "pulsed ground - open signal". Is this valve compatible with the DIY Autotune kit?
The DIYAutotune kit utilizes "a simple two-part kit with a 1/4w 620ohm resistor to replace R19 and a ZTX688b to replace Q4" and only mentions wiring +12v for valve to switched +12v (done by default) and "wire the negative wire from the idle valve directly to pin 30 on the MegaSquirt DB37" but this valve is a 3 pole valve... so... am I screwed?
Question about my idle control valve
Check the MS1/Extra site. There is a diagram.
In the past i've posted a circuit to drive the three wire valve. Some members use it on there cars with succes. Do a search for it...
SFC
SFC
Posted by email.----- Original Message -----
To: megasquirt-mss@msefi.com (megasquirt-mss@msefi.com)
Sent: Wednesday, May 24, 2006 6:55 AM
Subject: Question about my idle control valve
This post is at: http://www.msefi.com/viewtopic.php?p=121844#121844
Re: Question about my idle control valve
I guess my real question is what do I do since DIY Autotune provided a 1/4w 620ohm resistor to replace R19 and a ZTX688b to replace Q4? Build the circuit as per MSnS-E site and use my parts? Or what?
