by racingmini_mtl » Sat Jun 10, 2006 6:08 pm
Following the development of the hi-resolution MS1/extra code and for a future version of MS2 code (and MS3?), I have designed a small daughterboard that has 4 peak and hold injector drivers.
Since the hi-res MS1/extra code can't do a PWM signal on the injectors, the only solution with the standard MS injector drivers is to either use hi-z injectors or use inline resistors. This board allows the use of low-z injectors without any resistors and without setting up any PWM parameter since the chip (LM1949) the board is based on takes care of setting the current correctly no matter what the battery voltage is or what injector is there.
However, these drivers can only handle a single injector so the board can be used for engines with up to 4 injectors. For more injectors, more boards can be used.
I've designed the board such that there is one input per driver so each injector can be controlled by either of the 2 available MS injector channels (and this will allow 4 independent injector channels in the future MS2 code). Also, there is a single active flyback circuit for the 4 drivers as per Bruce's recommendation. The board layout assumes that the board will be used in either the lowest or the highest slot of the standard MS case with the 5 TO220 transistors bolted to the case. The initial board measures 4" by about 1.1" which means it should fit well in the case slot and be short enough to allow more than one board to be used. I still need to verify those measurements. The current BOM comes up to about $40 to $50 at Digikey but that does not include the board cost. However, if you are building a new board, all the injector driver parts are no longer needed so there could be some cost reduction there.
So, if there is some interest I could produce such a board. I would confirm everything before having the board made. I could also organize a group buy for all the parts needed. To have a significant reduction in price, the group buy would need to be for at least 25 boards. If there is no interest in the group buy, a smaller batch of boards could be done but the fewer boards made the higher the cost per board is.
So, let me know if you would want to buy such a board, how many boards you'd want, and if you would be interested in the group buy. I have attached the schematics of the board. Also, let me know if you have comments on the schematics.
