I have a strange issue that I would love to get some input on.
A while ago, I posted this:
http://www.msextra.com/viewtopic.php?t=22714
What finally got rid of it was loading an older msq. I figured it was simply a screwy msq, so I forgot about it.
A few days later, on the solid working map, I did some map tweaking while a buddy of mine was driving. After burning to ecu a few times with several different changes, I noticed the stutter came back.
At this point I figured the processor was screwy.
So I
1. Ordered a new chip,
2. Installed it and loaded msnse 029t
3. wrote a WHOLE NEW MSQ, from scratch, even entering the individual cells in the VE and timing maps.
Fired up the truck, took it for a run, and it stuttered. Not too severely, but it was there.
THINGS THAT TOOK PLACE JUST BEFORE THIS ALL BEGAN
This issue started just after I gave my unit to a buddy of mine, and he wired in the launch control circuit. He wired it up in the old style, like this
Just after that was the first few times that I ever noticed the stutter.
What really gets me is that its inconsistent, and if I load that older msq, it always cures it (until I start tweaking that map...)
HELP!!!!
degrading *.msq causing stutter under boost?
PCB V3.0
MSNS-E 029y4
400kpa MAP
Toyota Tacoma
2.4L 4 cyl. 16valve DOHC
Squirt: E85
Spark: LS2 coil wasted spark
MSNS-E 029y4
400kpa MAP
Toyota Tacoma
Squirt: E85
