Alpha test: 36-1+1
(Runs on MS2 and Microsquirt)
Alpha test: 36-1+1
Postby jsmcortina » Tue Apr 17, 2007 3:15 pm
Post info and test results here
I can supply, repair or upgrade Megasquirts in UK
Alpha test: 36-1+1
Postby rb26dett » Tue Apr 17, 2007 3:55 pm
Just to confirm, this is what used to be known as dual trigger
correct? ie a 36-1 on the crank, and a 1 on the cam?
Thanks,
Fred.
ms2,v3,cop,innovate,mazda fe3/fe-dohc 2l 4cyl with stock 10:1 pistons,4 stock coils,4 stock ignitors,rx7 550cc injectors maxed@6600rpm&17psi,custom everything,holset he351cw turbo,44mm ext gate,nis gtr bovs,nis gtr intercooler,70mm lexus throttle,chinese fpr,10may v2 ms2e alpha code
rb26dett
Postby jsmcortina » Tue Apr 17, 2007 4:07 pm
No, this is a crank wheel using a hall sensor and a funky 36-1+1 pattern. It is used (apparently) in next-gen Neons.
I have pictures of most of the wheel patterns and will add them to the manual when I get chance.
Alpha test: 36-1+1
Postby rb26dett » Tue Apr 17, 2007 4:14 pm
Then do I use the standard missing tooth wheel and just an extra check
box or two for the second trigger? excuse my ignorance, i had what i
thought was a good look around. i'll be playing with it again tonight,
hopefully looking for rpms to be shown.
Fred.
rb26dett
Re: Alpha test: 36-1+1
Postby jsmcortina » Wed Apr 18, 2007 2:26 pm
rb26dett wrote:Then do I use the standard missing tooth wheel and just an extra check
Fred.
Yes 36-1 crank wheel with second trigger cam wheel is a "standard toothed wheel"
Alpha test: 36-1+1
Postby rb26dett » Wed Apr 18, 2007 2:31 pm
Thanks James, Its just that I'm sure it was down as "dual wheel" in the beta.
Fred.
rb26dett
Postby boost junkie » Wed Apr 25, 2007 4:43 am
FYI, this wheel is used on all 03 to current chrysler engines (4, 6 and 8 cyl). Only the cam signals are different between them.
-shawn
msns-e controled turbo neon
sample msq's!
boost junkie
Postby jsmcortina » Wed Apr 25, 2007 6:34 am
OK, presently I've hardcoded this to 4 cylinders.
If someone can supply the timing information for 6 and 8 these should be fairly easy to add as well.
Having the cam signal data will also allow 4 cyl coil on plug now and pave the way for sequential fuel in MS3.
Postby jsmcortina » Fri Aug 10, 2007 3:26 pm
Anyone tried this yet?
Postby esteinmaier » Sat Mar 15, 2008 5:52 am
I'm trying it now. Using the RC1B code, I can't get it to get a tach signal set on 36-2+2. EDIS is the only setting that gives me any RPM, and it's obviously way off. I did successfully run MS1 on the car before, so I'm pretty sure it's not a wiring problem. Be easy on me, as I'm pretty noobish.
Try me.msq
(47.31 KiB) Downloaded 3 times
esteinmaier
Postby esteinmaier » Sun Mar 16, 2008 6:16 am
I switched to a firmware from November, and it read RPM just fine. Leads me to believe that the newest firmwares (Jan forward, at least) are broken for the NGC decoder.
esteinmaier
Postby jsmcortina » Sun Mar 16, 2008 6:35 am
Please post your two MSQs and the two firmware dates and I'll take a look on the bench.
Postby esteinmaier » Sun Mar 16, 2008 11:51 am
I overwrote the MSQs, so I don't have them anymore, but the 2 firmwares that I tried unsuccessfully were the new RC1b and the beta from 2/10/08. I configured the ignition as indicated in the manual for it for all of the above.
esteinmaier
Postby swnp » Sun Mar 23, 2008 6:08 am
I never saw this before... lmao...
James and boost, it works perfectly.
I posted my MSQ on (several) different post I've made here recently. I've been using this code since last summer/fall with the beta12 release(I think it was beta 12). I got it working well and have been using it w/o any problems since beta15.
I'm currently using it with RC1b and I don't believe that the problems I'm having with my fuel map are due to this wheel code.
Great work! All this time I didn't know it was still being "tested". lol I thought it was all said and done, because it works like it is.
(This is 2K4NightRiderSRT from the other boards, btw)
swnp
Postby jsmcortina » Sun Mar 23, 2008 6:33 am
Thanks for the feedback.
Postby swnp » Sun Mar 23, 2008 7:54 am
Hey, no problem, James.
All this time I didn't know I was "blazing the trail". lol I knew it needed testers from the other forums I visit, but I figured by the time I was using it, there would have been others. Honestly, I got my SRT4 started with this code before I got it started and running on my MSI-extra unit. I didn't just jump in and started using it because MS was totally new to me, and I wasn't confident enough (at the time) to learn EVERYTHING on my own. So I learned what I could from MSI, and now use the MSII exclusively on my SRT4.
And for the record, I've only spun the engine to 6000RPM. I plan on taking it to 7500 later, but so far I don't think it'll be a problem doing that as far as wheel code is concerned.
Cheers!
swnp
Postby swnp » Tue Apr 08, 2008 5:29 am
James, et al.
Is there anything with this code (I doubt it's the code, but I figured I'd ask here) that will cause the RPMs to drop out with low Z injectors? High Z injectors worked fine, but when the MS was switched over to low Z, the wheel decoding seems to break up from time to time.
Is it more likely that it's a hardware issue in the MS2 itself? I thought MS2 had native low z injector support?
Vic
swnp
Postby muythaibxr » Tue Apr 08, 2008 8:29 am
it's most likely that you need more grounds, or need to redo your power circuit. You may also want to check the megamanual for suggestions on what to do in this case.
muythaibxr
Postby Matt Cramer » Tue Apr 08, 2008 8:46 am
jsmcortina wrote:OK, presently I've hardcoded this to 4 cylinders.
FYI, I've confirmed that 8 cylinder engines use this same wheel. I have a cam wheel from one of the and intend to check it on a degree wheel soon - it's as weird as a Subaru setup.
Postby esteinmaier » Tue Apr 08, 2008 2:57 pm
I'm having the cutout problem too, and I'm going to first try a few more grounds. I already have it grounded well, but I'll do more. If that doesn't work, my next plan of action is to move the injectors off the board and onto a peak and hold board. From what I understand, this is a good idea anyway, so the peak and hold board is probably what I'll do.
esteinmaier
Next
Users browsing this forum: No registered users and 0 guests
