Page 5 of 7
Re: CANbus to Instruments etc. working
Posted: Wed Jan 09, 2013 12:25 pm
by racingmini_mtl
NArcher wrote:Sorry, another CAN question.
I have an ABS computer that I would like to receive the data from and pass to the vss to get speedo to work. Which part of the code do I have to modify to make this work. I am [also] a poor programmer
but am continuously learning!
Unless you actually removed the surface mount resistor from the board, your MS3 should have the terminating 120 Ohm resistor.
As for your second request, there is no support for receiving data from a device that is not using the MS CAN protocol (nor are there plans for it at this time as far as I know). So you would need to program that in and it's not a beginner project. And even then that assumes you actually know what the protocol and data format from the ABS computer are. If not then it is even more advanced and needs reverse engineering the CAN protocol.
Posted: Wed Jan 09, 2013 4:24 pm
by NArcher
Sorry, I didnt explain the situation clearly. The ABS computer is on the original CAN network of the car. I have the correct ID's and information to extract from the computer, I just don't know how to allow the megasquirt to receive the incoming ID. I do not have to poll for data as the ABS computer is constantly sending the information out on the network.
Posted: Wed Jan 09, 2013 4:28 pm
by stevevp
Firstly you have to open up the receive buffers to allow all can message in
in CanInit()
Code: Select all
/* Set identifier acceptance and mask registers to accept 11 and 29 bit messages from all devices */
CANIDMR0 = 0xFF; // anything ok in IDR0(var offset)
CANIDMR1 = 0xFF; //was 0xE7; // anything ok for var_off cont'd, msgtype
CANIDMR2 = 0xFF; //was 0xF0; // can be from any other device
CANIDMR3 = 0xFF; // any var_blk, spare, rtr
CANIDAR1 = 0x00; //was 0x18; // 0,0,0,SRR=IDE=1
CANIDAR2 = 0x00; //was can_id; // rcv msg must be to can_id, but now accepts any
/* 2nd 32-bit filter bank */
CANIDMR4 = 0xFF; // anything ok in IDR0(var offset)
CANIDMR5 = 0xFF; //0xE7; // anything ok for var_off cont'd, msgtype
CANIDMR6 = 0xFF; //0xF0; // can be from any other device
CANIDMR7 = 0xFF; // any var_blk, spare, rtr
CANIDAR5 = 0x00; //0x18; // 0,0,0,SRR=IDE=1
CANIDAR6 = 0x00; //0x0F; // rcv msg can be to everyone (id=15), and
then the interrupt routine needs to handle MSG_STD
in CanRxIsr()
Code: Select all
if(CANRFLG & 0x01) {
var_off = ((unsigned short)CAN_RB_IDR0 << 3) |
((CAN_RB_IDR1 & 0xE0) >> 5);
msg_IDE = (CAN_RB_IDR1 & 0x08);
msg_type = MSG_CMD;
if (msg_IDE) {
if ((CAN_RB_DLR & 0x0F)==15){// &0x0F = 00001111, get first 4 bits
msg_type = (CAN_RB_IDR1 & 0x07);
} else {
msg_type = MSG_STD;
rcv_id = CAN_RB_IDR2 >> 4; // message from device rcv_id
var_blk = CAN_RB_IDR3 >> 4;
var_byt = (CAN_RB_DLR & 0x0F); // &0x0F = 00001111, get first 4 bits
switch(msg_type) {
case MSG_STD: // message to be processed
msgID = (CAN_RB_IDR0 << 3);
msgID = msgID + (CAN_RB_IDR1 >> 5);
// 8 high bits in IDR0, 3 low bits in IDR1
// update variable value with received data
data[0] = CAN_RB_DSR0;
data[1] = CAN_RB_DSR1;
data[2] = CAN_RB_DSR2;
data[3] = CAN_RB_DSR3;
data[4] = CAN_RB_DSR4;
data[5] = CAN_RB_DSR5;
data[6] = CAN_RB_DSR6;
data[7] = CAN_RB_DSR7;
STD11_receive_CAN(msgID,data,var_byt,MSG_STD) ;
case MSG_CMD: // message for this ecu to set a variable to value in message
break;
then we need to process the STD 11 bit message
Code: Select all
void STD11_receive_CAN(unsigned int Rx_id, unsigned char *Rx_data, unsigned char Rx_dataLen, unsigned char flags)
// Receive Message Variables
// unsigned int Rx_id;
// unsigned char Rx_data[8];
// unsigned char Rx_dataLen;
// enable the following for debug if required
// ECANSendMessage(Rx_id+1, Rx_data, Rx_dataLen, MSG_STD);
if (flags == MSG_STD) {
flags = MSG_STD;
if (Rx_id == 0x280) // 4th byte of 0x280 is data[3] = (unsigned char)((outpc.rpm*4) /256 ); //byte 4 = RPM, H
outpc.engine_rpm = ((Rx_data[3])*64);
if (Rx_id == 0x520) // 2nd byte of 0x520 is lights and dimming 58d from 996 cluster
inpram.Dimming_58d = Rx_data[1];
Rx_dataLen = 8;
if (Rx_id == 0x661)
//h661 Radio/Navi, 8 byte, 100ms
//beim RNS-E wird hier zum Beispiel angezeigt, in welchem Mode das Geraet ist
//-h 81 01 12 A0 00 00 00 00 FM/AM
//-h 81 01 12 2F 00 00 00 00 SAT
//-h 81 01 12 A5 00 00 00 00 CD
//-h 81 01 12 A4 00 00 00 00 MP3
//-h 81 01 12 37 00 00 00 00 TV
//-h 81 01 12 3A 00 00 00 00 PHONE
if (Rx_data[3] == 0xA0) //radio active
//Set Relay On
PORTE |= 0x01;
else
//Set Relay Off
PORTE &= ~0x01;
Posted: Wed Jan 09, 2013 4:29 pm
by jsmcortina
Yes, but ...
racingmini_mtl wrote:there is no support for receiving data from a device that is not using the MS CAN protocol
Posted: Wed Jan 09, 2013 4:31 pm
by stevevp
There is now
Posted: Wed Jan 09, 2013 4:33 pm
by jsmcortina
stevevp wrote:There is now
Ha... true, you contributed some code (thanks.)
Posted: Wed Jan 09, 2013 4:43 pm
by NArcher
Thank you Steve! Exactly what I was looking for!
Posted: Wed Jan 09, 2013 5:18 pm
by racingmini_mtl
jsmcortina wrote:stevevp wrote:There is now
Except that this breaks the MS CAN protocol...
Posted: Wed Jan 09, 2013 5:36 pm
by stevevp
Agreed, which is why the receive code was not posted with the original transmit examples.
For a single MS device interfaced to the vehicle canbus only it will be fine
It could possibly work with one register set to 11 bit only and the other to the MS 29bit implementation with the device CanID but broadcast messages to all nodes on MS CanID 15 would still be excluded.
A better solution would be a coded filter in the receive interrupt routine for any message identified as 29bit and specifically rejecting messages without the MS CanID equal to 15 or the current device ID
So for anybody running multiple MS devices and MSquirt_CAN the receive mods above will not work without extra coding to re-implement the MS Can Filters
Posted: Wed Jan 09, 2013 6:04 pm
by racingmini_mtl
stevevp wrote:Agreed, which is why the receive code was not posted with the original transmit examples.
That could work but that could increase the number of interrupts significantly. All messages on the bus would create an interrupt. I'd have to check if even the messages sent by the MS would create a receive interrupt when configured with no hardware filtering as per the code above.
Posted: Wed Jan 09, 2013 6:07 pm
by stevevp
TX from the device will not be received by the same device unless loopback is configured
the following is pseudocode but gives a reasonable example
the address in MScan is here
Code: Select all
IDR2: |---From ID--|--To ID---| (Header bits 14 <-- 7)
The filter could conceivably be placed in CanRxIsr
Code: Select all
could become
Code: Select all
if ((CAN_RB_IDR2 & 0x0F)==15 || (CAN_RB_IDR2 & 0x0F)==flash4.mycan_id) {
} else {
msg_type = 99; // invalid and should cause a quick loop
Posted: Thu Jan 10, 2013 1:26 am
by NArcher
When I got the CAN ID's for the Mazda 3, the guy also gave me the bitmask for the ID's. What would these bismasks be used for? And does it relate to my implementation? The reason I ask is because I cannot get the engine temp gauge to function. The value of it should be X /4 where x is degrees C. Is the Engine_Temp variable in degree C?
Posted: Sat Jan 12, 2013 2:29 am
by NArcher
NArcher wrote:When I got the CAN ID's for the Mazda 3, the guy also gave me the bitmask for the ID's. What would these bismasks be used for? And does it relate to my implementation? The reason I ask is because I cannot get the engine temp gauge to function. The value of it should be X /4 where x is degrees C. Is the Engine_Temp variable in degree C?
Disregard, I figured it out!
Posted: Tue Mar 26, 2013 5:15 pm
by NArcher
@ stevevp,
Where do I put the third part of your code to rcv STD 11 msgs? Do I put it under the CANRxIsr()? Thanks
Posted: Wed Mar 27, 2013 1:15 pm
by NArcher
@stevevp
@jsmcortina
This is where I put the second part of the code, can someone tell me if it is in the correct place (Shown towards bottom of MS3 code)?
} else if (msg_type == MSG_CRC) { // msg to calc CRC32 of page - actually done in misc
if ((var_blk > 3) && (var_blk < 32)) {
flagbyte4 |= flagbyte4_cantuning;
tble_idx = var_blk;
flagbyte9 |= FLAGBYTE9_CRC_CAN; // set up to do the biz from the mainloop
// txbuf seems a fair place to store this data. Hoping nothing else tries to write it.
canbuf[4] = CAN0_RB_DSR1; // dest var blk
canbuf[5] = rcv_id;
} // end msg_type switch
can_status &= CLR_RCV_ERR;
else {
msg_type = MSG_STD;}
switch(msg_type) {
break;
} if ((CAN0RFLG & 0x72) != 0) {
// Rcv error or overrun on receive
can_status |= RCV_ERR;
//can_reset = 1;
/* clear RX buf full, err flags to ready for next rcv int */
/* (Note: can't clear err count bits) */
CAN0RFLG = 0xC3;
return;
To clarify, I am trying to get the abs wheel sensor data into MS3 to get speedometer. Then I want to send a signal to my instrument cluster to get speedo working. Any help is greatly appreciated!!!
Posted: Thu Apr 04, 2013 1:29 am
by NArcher
If I am trying to get the speed sensor signal to show up in, say CAN ID 1, can I use outpc.canin[0]?
Posted: Thu Apr 04, 2013 5:07 am
by jsmcortina
That field is intended for remote on/off inputs.
The VSS code expects remote VSS information to be deposited into datax1 in one of these fields:
Code: Select all
union {
unsigned int pwmin16[4];
unsigned long pwmin32[4];
union {
unsigned int vss1_16;
unsigned char vss1_8;
union {
unsigned int vss2_16;
unsigned char vss2_8;
Posted: Thu Apr 04, 2013 12:04 pm
by NArcher
jsmcortina wrote:That field is intended for remote on/off inputs.
Code: Select all
union {
union {
union {
Thanks James!
I know you're busy with the new 1.3, so I appreciate you getting back to me on this. Thanks again!
Posted: Mon Apr 08, 2013 7:59 pm
by NArcher
@jsmcortina
after correcting the errors and compiling my code for vss CAN, I get a "recipe for ms3.elf" failed. Can you explain what this type of error means? Thanks
*EDIT: Got it to compile. It was an error on my part.
Posted: Mon Apr 15, 2013 8:22 pm
by NArcher
Can someone tell me if this looks right:
Code: Select all
INTERRUPT void CanRxIsr(void)
unsigned char msgID, rcv_id, msg_type, var_blk, var_byt;
unsigned short var_off, dvar_off, jx, kx;
unsigned char data[8];
/* CAN0 Recv Interrupt */
if (CAN0RFLG & 0x01)
var_off = ((unsigned short)CAN0_RB_IDR0 << 3) | ((CAN0_RB_IDR1 & 0xE0) >> 5);
msgID = (CAN0_RB_IDR1 & 0x08);
msg_type = MSG_CMD;
if (msgID)
if ((CAN0_RB_DLR & 0x0F)==15)
msg_type = (CAN0_RB_IDR1 & 0x07);
else
msg_type = MSG_STD;
rcv_id = CAN0_RB_IDR2 >> 4; // message from device rcv_id
//var_blk = CAN0_RB_IDR3 >> 4;
var_byt = CAN0_RB_DLR & 0x0F;
switch (msg_type)
msgID = (CAN0_RB_IDR0 << 3);
msgID = msgID + (CAN0_RB_IDR1 >> 5);
data[0] = CAN0_RB_DSR0;
data[1] = CAN0_RB_DSR1;
data[2] = CAN0_RB_DSR2;
data[3] = CAN0_RB_DSR3;
data[4] = CAN0_RB_DSR4;
data[5] = CAN0_RB_DSR5;
data[6] = CAN0_RB_DSR6;
data[7] = CAN0_RB_DSR7;
STD11_receive_CAN(msgID,data,var_byt,MSG_STD);
break;
//unsigned int Rx_id;
//unsigned char Rx_data[8];
//unsigned char Rx_dataLen;
flags = MSG_STD;
if (Rx_id == 0x4B0)
{// 4th byte of 0x280 is data[3] = (unsigned char)((outpc.rpm*4) /256 ); //byte 4 = RPM, H
datax1.pwmin16[0] = ((Rx_data[1]) /100);
datax1.pwmin16[1] = ((Rx_data[0]) /100);
datax1.pwmin32[2] = ((Rx_data[3]) /10);
datax1.pwmin32[3] = ((Rx_data[2]) /10);
/*if (Rx_id == 0x201) // 2nd byte of 0x520 is lights and dimming 58d from 996 cluster
datax1.vss1_16 = (Rx_data[0]);
datax1.vss1_8 = (Rx_data[0]);
Rx_dataLen = 8;
if (Rx_id == 0x661)
//Set Relay On
PORTE |= 0x01;
else
//Set Relay Off
PORTE &= ~0x01;
I've been working on it for about a week trying to get the abs signals to vss1 and vss2 with no luck. Thanks
