MShift on Microsquirt
I bought a Microsquirt thinking I could run the Mshift firmware to control a 4T80e but everytime I flash it I have communication problems with the Microsquirt. I've tried multiple version and all do the same thing. I have had good results with James' Microsquirt trans controller firmware but I need to change more options than that has available. Any help would appreciated.
Re: MShift on Microsquirt
What additional options do you need?
I'm using an '06 4T80e and the internal range switch logic is different. I would like to be able control the input logic for each gear, the ouput logic is the same as a 4L80e so I don't need any change there. I would also like if I could switch the PWM time on PCS to match the 614 Hz solenoid that's used. If you just want to add another drop box selection for the 4T80e I can get back to you on the range switch logic. Thank you for the quick response.
Post it up, sounds easy enough to add.skalor wrote:I'm using an '06 4T80e and the internal range switch logic is different. I would like to be able control the input logic for each gear, the ouput logic is the same as a 4L80e so I don't need any change there. I would also like if I could switch the PWM time on PCS to match the 614 Hz solenoid that's used. If you just want to add another drop box selection for the 4T80e I can get back to you on the range switch logic. Thank you for the quick response.
Sorry it took so long to reply. Here's a pdf with the internal range switch logic. I don't need to change the PCS control, I'll just scale the tables down by 50%. Output settings are the same as a 4L80. I really appreciate the help so thanks in advance.
