Teensy-based CANbus gauge (and more)
Re: Teensy-based CANbus gauge (and more)
that looks great
if only they where this smart at innovate motorsports
if they could build a gauge wich could display everything that cam in over the serial or can line
one wich you could program yourself with any display you want
sort of like tthe sx displays of dta
do you think you could get that far?
displaying the can egt unit values?
possible log chain values from can egt if the can egt gets around to support them
Supporting the CAN-EGT is no more difficult than supporting any other data. The way to do this is exactly the same as for getting the data from an MS2 or MS3. And all the information needed is in the ini file.
could extra log chain channels easily be added to the can egt unit
suchs as an SSI4 unit?
or would that require an entire rewrite of the can egt code!
That's a significant update to the code. And what is more annoying is that I don't have the units for testing so that makes it more difficult to implement; doing that remotely with someone's help is a real pain.
I decided to make one for me with a 128x128 color Oled LCD. Thanks for the details on your project it helped me to understand the CAN protocol!
That built in CAN controller and available breakout board REALLY simplifies things compared to what I had to do with an arduino:
http://grassrootsmotorsports.com/forum/ ... 878/page1/
I wish there was a full CAN breakout board that can talk via SPI liko ADAFruit's GPS breakout. (hint-hint for board devs)
answer my own question. This looks promising: http://www.mikroe.com/click/can-spi-3.3v/
and in 5v: http://www.mikroe.com/click/can-spi-5v/
Sigh. Why didn't I see that a year ago when I was playing with this?
It doesn't look like the pitch between rows on those are correct for breadboard use, actually. double sigh
there are can shields for arduino which are exactly that; CAN to SPI. they are expensive, and bulky though. I do have one, but never was able to get it to do much due to the limited power of the arduino. The teensy changed all of that, with its easy to use built in CAN controller and powerful processor. It itself could be CAN to SPI if you really wanted, but it can be so much more (such as what I am using it for here).
If it helps any, i am breaking out i2c on the back with the intention of using a port expander to run things like gauge needle stepper motors.
Possibly almost an off-topic question, but why are these multitude of boards easier than using a plain microcontroller and making a PCB to suit?
e.g. the Freescale MC9S08DZ family has CAN, I2C, SPI etc. No need for SPI to CAN as the chip has an actual CAN module.
I think the main reason is the programming platform and the the plenty availability of libraries for the Arduino Platform.jsmcortina wrote:Possibly almost an off-topic question, but why are these multitude of boards easier than using a plain microcontroller and making a PCB to suit?
The Teensy board also have CAN onboard the only stuff you Need is a Transceiver (like the MS).
Another question which Platform do you use to Program the Freescale stuff?
Alfa 156 GTA
Alfa 75 Race Car MS III -- alway latest FW
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
Test MS II --always latest FW
Tunerstudio V2.6.11 Registered
MegaLog Viewer V3.4.04 Registered
Alfa 164 V6 Turbo
Alfa 155 2,5TD RIP
On my side, I build my own board with microchip components. I was using this small developement called the noogroove because I had it laying around, if not, I would have done it with a microchip microcontroller.
This was only a test and prototype so this is why I didn't designed a PCB.
James,jsmcortina wrote:Possibly almost an off-topic question, but why are these multitude of boards easier than using a plain microcontroller and making a PCB to suit?
If you look at the pictures I posted previously, you'll see that I needed to have multiple boards to fit everything. The Teensy was just one in the complete package. And the price of the complete board is very close to what it would cost me for the bare board plus components. I had a look at making a board to have a slightly better fit and that didn't make much sense in terms of cost and work involved.
And this is for an open source project so using a common and widely used platform makes it a lot more user friendly. There are many libraries already present and more being created. And the processor used on the Teensy is a quite powerful one so even if the firmware is not as optimal as one created for this specific task, it will still be more than adequate for the job.
@Suprazz - what display is that? Do you have a link?
fun is not a straight line
Sven
Sven
Looks like a 4D Systems 128 G2...Zaphod wrote:@Suprazz - what display is that? Do you have a link?
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
James,
Yeah being able to leverage the Arduino libraries was a big thing for me. I am fairly new to embedded programming but have a couple decades of scripting experience under my belt so i am familiar with coding but have a hard time making the transition to compiled languages and then to embedded. I do very much dislike the Arduino "IDE" though and have made good progress in using an IDE meant for c/c++ (in this case, QT Creator) to compile for the Teensy (still using the Arduino libs though). For the $17 it costs for the Teensy module, it is not worth designing my own circuit from scratch and losing the nice Arduino compatible bootloader and such. And with the nice compact size, I wouldnt gain much space physically either.
I will have to look into that display. Some of it will be covered up by the LED ring, but it would still be nice to have more real estate. And color. The arduino that the display code was originally written for didnt have enough memory to do more than the 128x64 monochrome display but the teensy does.
And here is the final prototype. very happy with how it turned out.
Nice enclosure!
I have one, too, but I want a breakout board.xrattiracer wrote:there are can shields for arduino which are exactly that; CAN to SPI. they are expensive, and bulky though.
Beautiful, I like how it turned out! When will they be available for buying...? ;-)xrattiracer wrote:And here is the final prototype. very happy with how it turned out.
Btw. in my case- I wouldn't even need an enclosure, because it will be in the dash anyway...
Greets
Sven
Sven
Sven
What software are you using for PCB board design?
Where did you have them fab?
Really nice project!
Sam
Sam
I am using Cadsoft Eagle for design, and have them made through oshpark.com
