Speeduino ECU
Speeduino ECU
Postby DaveEFI » Sun Nov 13, 2016 5:16 am
On a totally unrelated forum I heard about a Speeduino ECU which apparently uses Tuner Studio. I was asked for some help with a project, so wanted to check it was a legal use before proceeding.
DaveEFI
Re: Speeduino ECU
Postby muythaibxr » Sun Nov 13, 2016 5:34 am
If they are using our comms algorithm, it is not legal.
:msq:
muythaibxr
Re: Speeduino ECU
Postby kjones6039 » Sun Nov 13, 2016 9:08 am
Looks like another one trying to sneak in the back door, if you ask me (which no one did of course!).
MS2 v3 w/extra 3.4.2 Release
kjones6039
Re: Speeduino ECU
Postby DaveEFI » Sun Nov 13, 2016 12:07 pm
kjones6039 wrote:Looks like another one trying to sneak in the back door, if you ask me (which no one did of course!).
It's not an MS clone - by what I've seen of it (pics etc). It's an Arduino based open source project. But I know very little else.
DaveEFI
Speeduino ECU
Postby subwoofer » Sun Nov 13, 2016 1:06 pm
muythaibxr wrote:If they are using our comms algorithm, it is not legal.
Do you mean the protocol, or the parsing code? Can you copyright a protocol, I thought you could only copyright the implementation.
I am in no way involved in said project, just to make that clear.
Joachim
1974 Jensen-Healey
2014 Ford Fiesta EcoBoost
subwoofer
Re: Speeduino ECU
Postby kjones6039 » Sun Nov 13, 2016 1:21 pm
DaveEFI wrote:It's not an MS clone - by what I've seen of it (pics etc). It's an Arduino based open source project. But I know very little else.
Yes, I realize it's not a clone. My comment was in reference to the concept of using TunerStudio. Gotta be something wrong with that! :lol:
kjones6039
Re: Speeduino ECU
Postby grom_e30 » Sun Nov 13, 2016 1:51 pm
http://speedtalk.com/forum/viewtopic.ph ... 12&start=0 have a read on this it sounds like they have permission to use it with tuner studio.
grom_e30
Re: Speeduino ECU
Postby kjones6039 » Sun Nov 13, 2016 2:40 pm
grom_e30 wrote:http://speedtalk.com/forum/viewtopic.php?f=1&t=44612&start=0 have a read on this it sounds like they have permission to use it with tuner studio.
Looks like Grom is correct AGAIN! (just kidding :lol:)
I am guessing that Phil may chime in here and put all of our minds to rest. :D
kjones6039
Re: Speeduino ECU
Postby grom_e30 » Sun Nov 13, 2016 3:00 pm
on a side not while looking in to this i came across an arduino project called: ardu-stim which is an Arduino based crank/cam wheel signal generator that may well come in handy to megasquirt users.
grom_e30
Re: Speeduino ECU
Postby slow_hemi6 » Sun Nov 13, 2016 9:13 pm
It says on phils website that his software is used with a number of different ECU and MLV in particular is very usable by many applications that store in CSV format. Says some universities are even using it for data analysis. I have used data from winlog (tech edge) and displayed it with MLV. Not that hard to do.
slow_hemi6
Re: Speeduino ECU
Postby mickeymarrows » Mon Nov 14, 2016 3:30 am
grom_e30 wrote:on a side not while looking in to this i came across an arduino project called: ardu-stim which is an Arduino based crank/cam wheel signal generator that may well come in handy to megasquirt users.
on a side note, I use that all the time (ardustim). Its clunky but works brilliantly.. :)
'82 Golf GTI ABF 16v MS2 Extra sequential COP
'77 Scirocco G60 MS2 Extra sequential
mickeymarrows
Speeduino ECU
Postby muythaibxr » Mon Nov 14, 2016 8:25 am
James and I designed the comms proto, and they don't have our permission to use that. Assuming they are using it.
:msq:
muythaibxr
Re: Speeduino ECU
Postby LT401Vette » Mon Nov 14, 2016 9:07 am
I appreciate all keeping an eye on these things as we are continuously fighting MS2 Pirates and there is commonly groups of people using TunerStudio without permission.
From looking at the ini, they appear to be using a protocol closer to the MS1 protocol. A basic request reply protocol with no error checking.
To my knowledge the Speeduino project is quite different from MegaSquirt, I believe it is primarily a small group of hobbyists.
In the case of speeduino they did originally start using TunerStudio just because it was there, but did then request permission. I have granted that permission so their use is fine.
LT401Vette
Re: Speeduino ECU
Postby muythaibxr » Mon Nov 14, 2016 9:48 am
OK fair enough.
:msq:
muythaibxr
Return to Tuner Studio
Users browsing this forum: Bing [Bot] and 1 guest
