I am looking for help with the connections for a Keihin pump as used on the Honda TRX series.
From what I can gather, #1 goes to the injectors, #2 is the fuel from the tank and #3 is the return to the tank.
Additionally, I cannot find the polarity for the electric connection.
Can anyone tell me which is positive and negative, A or B?
Keihin Pump Connections??? (BMW 700 - A Car)
- Attachments
- Pump4.JPG (379.26 KiB) Viewed 4132 times
- Pump2.JPG (344.9 KiB) Viewed 4132 times
Re: Keihin Pump Connections??? (BMW 700 - A Car)
A=-
B=+
1= high pressure to injectors
2= fuel in from tank
3= return to tank
I am not positive but I think that pump needs to be gravity fed.
I don't think it will work if the tank is lower than the pump.
B=+
3= return to tank
Thanks for the data OldGuy! I will be feeding it with a low pressure pump.
Regards, Ray
Regards, Ray
I found this connector on ebay. A perfect fit!
https://www.ebay.com/itm/255067299748
- Attachments
- connector.jpg (98.62 KiB) Viewed 3770 times
