Cranking pulse %
(Runs on MS2 and Microsquirt)
Fabricio
Cranking pulse %
Post by Fabricio »
Hello,
Could you please clarify the reason cranking pulse is limited to 33 ms? Is it something related to SW / HW capabilities?
I have an issue regarding start quality, I believe a higher time would improve it if allowed by the controller.
Thanks in advance!
Marek
Re: Cranking pulse %
Post by Marek »
Why don't you make your reqfuel value higher and then reduce your ve table by the same amount?
kind regards
Marek
Fabricio
Post by Fabricio »
Hello Marek,
It does not work changing the values from reqfuel and VE table. The time is limited by the SW at 33 ms.
PW_limit
PW_limit
Marek
Post by Marek »
The first thread you posted to has a reply from the programmer who wrote the code explaining this and also has some workaround strategies which may help you.
kind regards
Marek
Fabricio
Post by Fabricio »
The programmer said what the limit is, but did not explain why.
The other strategies do not solve the problem because my injector has a low flow rate and the fuel used is Ethanol, which has a hard time burning at low temperatures.
I would just like to understand the reason for this limitation because a solution might be changing the source code.
Fabricio
Post by Fabricio »
Good afternoon jsmcortina
Please explain to me why the injection pulse at engine start is limited to 32 milliseconds
Fabricio
Post by Fabricio »
Although Megasquirt is an Injection module and ignition really good, I understand the reason that Fuel Tech is dominating the World.
